Results 1 to 6 of 6
Thread: 130 or 135
07-29-2015, 03:00 PM #15000 RPM
- Dec 2006
- SC
- 250
130 or 135
Looking at two center consoles 18ft both boats are 1997 in great shape one has a 130 yamaha and one has a 135 mercury both are offshore models witch one is a better motor? Both look like they have been well taken care of. Any idear weight and hp thanks.
07-29-2015, 06:27 PM #2
Go with the merc
02 mirage ski racer w/ 2.5
lake tarpon (LTB racing)
"Mirage Boats... often imitated but never duplicated"
07-30-2015, 04:48 AM #36000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
The Yamaha is a 4 cylinder engine. The merc is a V6. The V6 will have more torque and will use a larger prop, which is better for control of the boat and torque. Appears that year 135 was the Optimax model, which is a more fuel-effiecient direct-injected engine than comparable carbed engines.
07-30-2015, 06:02 AM #45000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
No question the V6 will have a lot more than 5 additional HP- I am not sure about that year being an Opti . If it is a carb 2.0 lt- it will be basically a 150 hp and a very good engine.
With all that said the Yammie is rock solid design also- just not as powerful.
If the merc is an Opti- I would not touch it. Check what used Optis sell for vs other motors- including carb mercs same age.
07-30-2015, 06:43 AM #55000 RPM
- Dec 2006
- SC
- 250
They are both 1997 model motors, the mercury is not a optics from what I can tell.
07-30-2015, 07:42 AM #65000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
I do not think it is an Opti based on quick look- I had a 140 hp V4 O/B then switched over to a 150 V6 on same boat- hugh difference.
On the merc- suggest you check steering arm and lower mounts-yoke for corrosion. CC implys salt water use- the steering arms and lower yoke/mounts on that age merc were subject to corrosion. The corrosion can be stopped by using corrosion x or fluid film. Both products work.
