Page 11 of 142 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 61 111 ... LastLast
Results 151 to 165 of 2122
  1. #151
    Sep 2010
    long island,ny
    Joe the only flaw if you can call it that is with all that warranty you will be hard pressed to do any upgrades to motor JMO
    Fullers is both a Premiere Mercury and BRP dealer and BRP is a stickler for warranty work. They require engine reports for everything.
    Good to know Mike. Which motor would your shop recommend better for this Tuff 21' ? The G1 or G2 ??
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  2. #152
    Quote Originally Posted by dnelson964 View Post
    Wow Dr talk about putting someone on the carpet. George and Kev went out to the introduction of the G2 when it came out. They rode in multiple boats with the G2 and for George with his Merc background to be impressed says a lot. Unfortunately nothing was rigged on anything like a sob so all I can say is the Etec has lots of grunt and that 7 year warranty is to die for. Hows that for being a politician With that being said get something together so I can bring the super up there before the summers over.
  3. #153
    Long Island N.Y.
    I know i wouldnt touch it during the warrenty period, If I have the motor that long, if it becomes an issue as far as performance Ill just install the x Im buying, and sell the G1, to start modify that motor and lose the warrenty would defeat one of the reasons why Im buying one
  4. #154
    Long Island N.Y.
    think about 7years! even if the boat was slower than the XS who cares
  5. #155
    Quote Originally Posted by Dirk Pitt View Post
    Yeah considering what it cost to replace, fuel inj, air inj or compressor on a XS out of warranty makes the argument right there.
  6. #156
    Sep 2010
    long island,ny
    All and any new info is good Mike......Motor starting to sound like an experiment space ship looking to be the new 'Maytag'. I think they need to offer solid mounts on them is my first recommendation.
    See what can be worked out for a get together in future.....
  7. #157
    Quote Originally Posted by gm250 View Post
    mike sounds like the xs has alot of issue. I heard the xs is not working well on any of the progressions thinks I will stick with the fish motor. joe the tuff will look awsome with a white motor . if it runs good numbers great on fuel why ever look back at black. think I would buy a used lower and trick it out
    we mod the 3.0 sporty to bolt up to the g1. I've done a few for friends and my brother. The way I do it allows you to swap the case back to stock at the boat ramp if you wanted. The factory mid, lower, water tube, drive/shift shafts are all left stock. Warranty saved
    But I've been 105with a stock m2 no nose cone 1.85 gear and a worked 15x34et so I don't think the sporty is nessasary for this application.
  8. #158
    Long Island N.Y.
    mike sounds like the xs has alot of issue. I heard the xs is not working well on any of the progressions think I will stick with the fish motor. joe the tuff will look awsome with a white motor . if it runs good numbers great on fuel why ever look back at black. think I would buy a used lower and trick it out
    theres alot of them around here, its just not worth having change this, change that, modify this, modify that, (although some of the flyers have come up with some great ideas) ,all for a mere $200000,00
  9. #159
    Long Island N.Y.
    Mike
    do you still have the same boat that the glass work was done, I forget did you close up the well? or did you add a notch?
  10. #160
    Mike
    No Joe I sold the challenger before I bought Ragus super. The well was still stock. Joey did the notch and fixed a crack in the hull. Wish I still had that boat. Would have made a great class 7 boat.
  11. #161
    Long Island N.Y.
    Ragus boat is a piece of jewery, I was involved in every step when mike had raybo actually rebuild that boat, raybo of course did a masterful job, and Rague spend a ton doing that project, you bought the right one....
  12. #162
    Now if I could just get it over 105
  13. #163
    Long Island N.Y.
    the way I see it is the boat stock is faster then the others the motor is far what 280 hp great on gas great combo for everyday use. if you grabbed a lower for $1000 and modded it you would have a great setup. I run a stock yamaha and have fun with great fuel economy merc's around hear don't want to run us anyway. the retirement rate is high on Long Island for merc the only guys that are left that will run are p22 and hoser. Yamaha makes 280 hp just like etec
    I hope Merc is reading this, as far as hp joey who is running this show, tells me the G1 makes about 304 hp, he has been talking to BPR tech for some time, he cut his teeth with Evenrudes, but as you know he has been merc's poster child for over 40 years, there was a time when merc came out with a new race motor for the big guys, they went with joey, during that time I must have bought (all New) maybe 15 different variants of their products, and I must say Mercury was always very good to me, whenever I had an issue, but he was the one that pushed me over the edge to go white
  14. #164
    Long Island N.Y.
    Mike I drove that boat many times it always felt light to me, I know first hand how much weight Raybo saved during the rebuild of your boat, its a beauty!!! I know your close stop Im sure on a chrisp october morning, with the back seat out and a non labbed 4 blade et your north of 95mph your running a x right?
  15. #165
    Yes Joe and Im already north of 95. Have a trim pump issure that I will get to this week than its ready to roll.
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
