Results 1 to 15 of 15
Thread: e-tec 150ho dyno test
07-22-2015, 03:06 AM #1Member
- Mar 2004
- Norway
- 40
Interesting to see the power and torque curve :
http://www.lundinsmarin.se/index/dyno150ho_28-2-1.jpg
done by swedish tuning company. Lundins Marin. http://www.lundinsmarin.se/
Maximum power is below 5000 rpm. I
07-22-2015, 06:01 AM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
"After many years of research, Lundins Marin R&D have developed a technology to upgrade some Evinrude E-tec engines, etc."?
07-22-2015, 06:23 AM #3Member
- Mar 2004
- Norway
- 40
They remap the ECU like on car engines. They claim it will not change the ID code of the ECU and will not show that anything is done while on service.
I have read on some swedish forums that it works very well but I am no expert and can not "vouche" for it.
This is for Verado:
MERCURY Verado 135hp - upgrade to 175hp!
MERCURY Verado 135hk(2007-) - upgrade to 200hp!
MERCURY Verado 200hk - upgrade to 275hp!
MERCURY Verado 225hk(2007-) - upgrade to 300hp!
07-22-2015, 06:56 AM #4Member
- Mar 2004
- Norway
- 40
For the tuned 150ho the maximum torque is around 4000 rpm and max HP just below 5000rpm. This particular engine has recommended rpm from 5300 to 6000. The measurements will suggest to have wot at 5000 to get the most power. I have a 200ho and wonder how the torque and power curcves are for it.
07-24-2015, 08:12 PM #5Team Member
- Lake Coochiching, Ontario
- 7,746
- 271
- 485
- 1570
- 6 Post(s)
propshaft or crankshaft HP?
07-27-2015, 08:49 AM #6Member
- Mar 2004
- Norway
- 40
07-27-2015, 02:26 PM #7
Interesting. I race with a 150 HO and have always found that a 28P prop running 4800-5000rpm gives the best performance. We have tried a 24P of the same style and always found it felt a little 'off' vs the 28P. Real world testing that is confirmed by dyno data is always good!
olboatman liked this post
07-27-2015, 07:16 PM #8Team Member
- 7,746
- 271
- 485
- 1570
- 6 Post(s)
corrected for atmospheric conditions or raw numbers? big for a 150 either way
07-28-2015, 01:23 AM #9
That data is for a stock 150ho? Any Idea what gains they get with the tuned 150ho?
07-28-2015, 01:46 AM #10Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
hard to believe you can get much from an opti without porting
07-28-2015, 07:50 AM #11
just a little outside the NMMA 10% window! Powerful.
07-28-2015, 07:58 AM #12Member
- Mar 2004
- Norway
- 40
The data is for a tuned 150HO and regular 150. I think the torque is very good at 300 Nm
07-28-2015, 07:01 PM #13Team Member
- 7,746
- 271
- 485
- 1570
- 6 Post(s)
They don't actually rate it as a 150. For years, the brochures and on line data has said 'factory tuned for high performance' instead of 150 HP
http://www.evinrude.com/en-ca/engine...ho/etec_150_ho
Maybe when I get tired of putting gas in my Promax...On the other hand, if the 150 HO had as much torque <4000 as the Promax, I could swap sooner.
08-27-2015, 07:59 AM #14Junior Member
- Dec 2012
- fargo north dakota
- 9
so if i am to understand this correctly, a stock 150 ho should run wide open around 5000 rpm, and this goal rpm should be achieved solely by having a proper diameter/pitch prop?
09-09-2015, 12:15 PM #15
Wait, so this is a modified motor? This is the 60* motor right. Any figures on the 200- 60* motor?
e-tec 150ho true power
By nate. in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 15Last Post: 03-22-2011, 11:04 PM -
etec 150ho upgrades
By nate. in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 08-17-2010, 04:25 PM -
Evinrude 150HO propshaft hp ?
By Toffy in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 37Last Post: 08-15-2010, 01:14 PM
