Results 1 to 1 of 1
Thread: 40 Johnson 1984
    Sep 2008
    charlestown, ri
    40 Johnson 1984
    I've got a 1984 40 OMC 20'' i'm looking to get out of my motor shed. It's super clean for the year... block has little if any corrosion. looks a little faded, but really nice inside. compression was 145/95. Pulled the head and bottom cylinder is all chewed up. was hoping it was just the headgasket... wishful thinking. Sleeve is a little more than hairline cracked. Might have spun a locator pin and ring then caught on exhaust port. The pieces from the ring probably beat up the piston and ruined the head. All the other parts look really nice. Doesnt look to have been apart. A new sleeve and piston should let it run like new. Lower unit in excellent shape. Propshaft is strait as an arrow. Looking for $250 firm.
    Located in RI... pickup only guys sorry unless someone wants some of the big parts.
    Attached Thumbnails Attached Thumbnails IMG_20150717_174928263.jpg   IMG_20150717_175000606.jpg   johnson40.jpg
  1. OMC Tech: 1984 johnson 75 hp low compression
    By JoshKeller in forum Technical Discussion
    Last Post: 10-03-2014, 07:18 PM
  2. OMC Tech: 1984 johnson 185hp
    By dannytorres in forum Technical Discussion
    Last Post: 09-22-2013, 03:34 PM
  3. 1984 Johnson 185 HP
    By BigBrud1958 in forum Technical Discussion
    Last Post: 05-31-2011, 09:37 PM
