Results 1 to 4 of 4
Thread: wiring 70 hp johnson 1987
07-08-2015, 11:13 PM #1Junior Member
- Jul 2014
- Gatineau Canada
- 18
Would anyone have an accurate wiring diagram of a 70 hp johnson 1987?
I just bought it rebuilt and will use a seastar control and ignition switch. The 2 online manuals I bought have errors on just about everything. No luck on the web. Original shop manual on it's way but 2 - 3 weeks to get to me.
07-08-2015, 11:56 PM #2
The wire colors at the dash should be:
Red - 12V positive
Black - 12V Negative
Black/Yellow Stripe - Ignition Kill
Purple - 12V Positive with Ignition On
Blue/White Stripe - Choke/Primer
Yellow/Red Stripe - Start
Gray - Tachometer Signal
The trim Harness will be:
Red -12V Positive to switch
Blue - Up Circuit to switch
Green - Down Circuit to switch
Brown - Trim Sender
Black - Trim Sender Ground"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
07-09-2015, 08:09 AM #3Junior Member
- Jul 2014
- Gatineau Canada
- 18
Thanks for the fast reply. All colours match on the motor.
Next question:
It should look like this on my switch?
Provide + for gauges from pin A
Neg from first pin M
Ground Black/Yellow Stripe - Ignition Kill from 2nd M pin.
B = Red - 12V positive
M = Black - 12V Negative
2nd M = Black/Yellow Stripe - Ignition Kill
A = Purple - 12V Positive with Ignition On
C = Blue/White Stripe - Choke/Primer
S = Yellow/Red Stripe - Start
Outside my switch to rpm gauge = Gray - Tachometer SignalLast edited by Ram_Boat; 07-09-2015 at 08:18 AM. Reason: trying to get the picture to show clearly
07-09-2015, 04:24 PM #4
Yes.... you got it......
Wiring diagram for 1987 Hydrstream vegas with 200 johnson
By neub211 in forum Technical DiscussionReplies: 1Last Post: 04-07-2015, 10:25 AM -
OMC Tech: Johnson wiring questions
By 0081 in forum Technical DiscussionReplies: 23Last Post: 02-24-2014, 01:41 AM -
1984 Johnson 235 hp wiring
By Liberator225 in forum Technical DiscussionReplies: 1Last Post: 07-26-2011, 03:57 PM -
OMC Tach Wiring - Johnson RS
By RogerH in forum Technical DiscussionReplies: 10Last Post: 01-16-2010, 04:15 PM -
2000 200 johnson need wiring help please
By shat70 in forum Technical DiscussionReplies: 1Last Post: 04-17-2007, 10:20 AM
