Results 1 to 4 of 4
Thread: 1993 xr6 2.5
    Jul 2015
    La
    1993 xr6 2.5
    I recently bought a 93 pro craft super pro 18' the cowling says xr6 2.5 150. But the guy I bought it from said it was to hard to start so in 2009 He took it to a marine dealer and had it converted to a EFI now the ecu on the motor says it's a 2.4? Is there anyway I can tell what I have? Is it a 150,175, or a 200? He said it had a 200 computer on it I haven't taken it off and looked. It's a hand full to drive but will run 74.3 loaded with 2people and I'm turning an old Hopkins 26p prop that has been thinned and worked.
    St. Amant, LA
    I would look at the serial number on the clamp bracket and see if there are numbers that match on the block then look up on the Mercury website.
    22R
  3. Thanks RedonYellowKillaFellow thanked for this post
    Jun 2011
    phoenix
    There should be a silver freeze plug on the top of the block with a member stamped in it. Write down or take a pic of the #. Your merc dealer, or possibly someone on here, will be able to tell you what powerhead you have
    Jun 2011
    phoenix
    Number not member. Stupid auto correct
