Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
    Feb 2007
    Western Washington State
    Quote Originally Posted by WillDiver View Post
    my 17' Kona, with a '78 1500 turns about 5200 at 48 MPH running a 19" prop. I need a carb job, and a link n sync, then I expect 5500 and just barely north of 50. The trigger can sometimes go wonky on those. CDI has a website (I dont recall the link) that gives troubleshooting instructions for the trigger.
    Will
    I know this is kind of hijacking this thread, but... You need to get the 1500 spinning higher! Those low rpms on those motors will kill them faster than a little over-revving. That thing should be turning 5800-6000 all day long!
  2. #17
    May 2015
    SoCal
    Quote Originally Posted by croSSed View Post
    Yeah, I just got the boat a few months ago, and havent been on the water too much yet. I figure going from a 3 blade 19" to a four blade 17 or 19 will help with that. also I really need to tear into the carbs....and pretty much replace the entire fuel system. Luckily, its all easy stuff, as long as I can find the right parts.
    Will
  3. #18
    Aug 2011
    Quote Originally Posted by milkdud View Post
    Post the serial number off the motor and we/I will tell you. If its falling that flat at 5100RPM, then I can almost guess its a 90. Can you also post a picture of the motor?
    Ok - the number on the clamp says its a '78 90HP... but we know the powerhead was changed before we got it 24 years ago. The only number that could be found on the block is 8526627
    1986 Hydrostream Valero YT - Fully restored '12.
    1997 225 Promax.
  4. #19
    Jun 2009
    Middle USA
    852xxx is a casting number, won't help.
    Is there a freeze plug on the starter side near the intake covers? Many were set stamped on that plug. Check the distributor arm.
    Im guessing its a 90.
    L6fan57-88
  5. #20
    May 2015
    SoCal
    On mine it looks like this. Starboard side.
    Will
  6. #21
    Jun 2009
    Middle USA
    WillDiver. FYI I think that P at the end of the Serial Number is a Pace Maker block. Factory rebuilt back in the day.
    L6fan57-88
  7. #22
    May 2015
    SoCal
    Yeah, Ive been told that. The serial number on mine isnt on the transom clamp anymore, so I had to do some looking around. The decals are all for an earlier 1150, but when I looked up the block, its a 78 1500. and also verified via the carbs (WMK-22) and a few other unique items. it was an interesting investigation.
    I just ordered my carb rebuild kits, new floats, and fuel pump kit. guess I'm gonna play a little bit.
    Will
  1. Water where it shouldn't be!!!
    By Gasguzzler in forum Technical Discussion
    Last Post: 07-06-2015, 04:45 PM
  2. Replies: 16
    Last Post: 07-18-2013, 10:05 PM
  3. Mercury Tech: 3.0 250 merc wont rev up past 2000 r.p.m timing goes haywire
    By SCOOBARON in forum Technical Discussion
    Last Post: 03-31-2012, 01:29 AM
  4. merc 280 not turnin past 3000 rpm
    By SPECTRE racing in forum Technical Discussion
    Last Post: 09-24-2008, 05:42 PM
  5. You CAN park here-but you shouldn't
    By fastboat in forum General Boating Discussion
    Last Post: 06-11-2002, 05:25 PM
