Results 1 to 2 of 2
06-28-2015, 08:53 AM #1
When my 2000 merc slowly drops when trimmed up ?
What would cause this? All three pistons creep down no fluid leaking takes a few hours,
06-28-2015, 08:47 PM #2
It could be the seals inside the unit are causing it to leak down.
- Make sure there is enough fluid in the system
- Make sure the manual leak down screw is tight.
-Have you bled the air out the system to be sure?"If everything's under control, you're going too slow"
-Mario Andretti-
76 vixen,.. on the back burner
82 laser comp. 380 ray
PICS OF THE VIXEN REBUILD
Mercury Tech: Laser 220 - runs better trimmed up, smokes/overfuels when trimmed back down?
By gmacrae in forum Technical DiscussionReplies: 6Last Post: 12-07-2014, 08:17 PM -
Slowly making progress on my daughters boat
By Riverratt in forum General Boating DiscussionReplies: 38Last Post: 08-17-2012, 02:08 PM -
Merc Laser 220 XRi runs bad when trimmed down
By gmacrae in forum Technical DiscussionReplies: 81Last Post: 11-02-2010, 03:57 PM -
Mercury Tech: oil sensor beeping when trimmed up
By Sheer Insanity in forum Technical DiscussionReplies: 2Last Post: 06-03-2009, 08:00 AM -
Power tilt...slowly drops
By rocketmerc in forum Technical DiscussionReplies: 6Last Post: 07-17-2007, 01:05 AM
