Results 1 to 3 of 3
    norwell massachusetts
    exhaust mod omc 55 hp 2 cyl questions
    Engine is 55672e = 1976 55hp 2 cyl short shaft. I want to mod this engine for top end speed on a dux super light tunnel hull. No heavy loads,skiing, just going fast.
    Questions,exhaust mods? cutting out the rectangular restriction located between the mid and gear case, where the 2 bolt up. There is a rectangular rubber gasket that seals when bolt up. There seems to be lots of metal I could remove to open up this passage, at least 3/4 inch on sides and 1/2 both ends. Is this ok? or is this part of the tuner can?
    Question on compression , 180 lbs on both, tested several times 2 gauges, engine throttle open full and was cold. Is that about the max for pump gas?
    Question ignition? has terminal box cdi type, is there a rpm limiter? what is max rpm limiter setting? How to remove rpm limiter? ignition timing Idle? max?
    Question Carbs, what jet size
    Mods for 2 cyl omc? grinding,cutting ports? intake or exhaust?
    Thanks for help.
    Side note? I have this 55 rude 2 cyl and a 3 cyl yammy both 2stroke & shorts. Best or your choice what one to run on my super light tunnel? and what one responds to mods?
    Savannah GA
    I am not very knowledgeable about racing motors but I would think that 180 psi compression would require some jet fuel mixture. I would think that jet size would be some trial runs and spark plug reading, I would start out a little rich.
    Oct 2010
    Harrisburg,Pa
    Go with the yamaha, the 55 will have ignition issues. Plus the 55 must be carbon up pretty much to have that kind of compression.
  1. Exhaust questions/parts
    By cographix in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 12-07-2007, 12:12 AM
  2. exhaust questions
    By trimmed out in forum Technical Discussion
    Last Post: 05-15-2007, 06:35 AM
  3. Questions about exhaust logs and risers
    By 72BBO in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 04-06-2007, 01:08 AM
  4. Exhaust plate & Tuner questions
    By Jeff "Yammer" in forum Technical Discussion
    Last Post: 12-06-2005, 04:33 PM
  5. More Exhaust questions
    By Dingie in forum Technical Discussion
    Last Post: 04-14-2005, 01:43 PM
