Results 1 to 15 of 18
Thread: Alpha gimbal bearing question
06-17-2015, 07:32 AM #1
Have an '86 boat w/an Alpha drive that needs a gimbal bearing.
I have The drive off to inspect the bearing it looks like a retainer screwed in to the gimbal assembly to retain the bearing. Doesn't show in any of my breakdowns and I've searched online but don't want to destroy it with the puller.
can one of you experts shed some light on this for me please?I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
06-17-2015, 07:41 AM #2
Ps, thought it was supposed to be in neutral to remove.
Did I tear anything up and how do I check?I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-17-2015, 08:03 AM #3
Should be in forward there is a tool to set cable length I would start there to make sure it's not stretched, etc.
http://youtu.be/Dj9LLfJEikA
posts about instigator "saw the light" "finally went to the dark side" in 3......2.....1.....Last edited by baja200merk; 06-17-2015 at 08:05 AM.
06-17-2015, 09:02 AM #4
Anyway to post a pic?
06-17-2015, 09:09 AM #5
Do you have the correct bearing driver and alignment bar? Pretty important to have things lined up correctly.
I've forgotten to shift to fwd before and not hurt anything. Get rushed in winterizing season.
06-17-2015, 10:41 AM #6I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-17-2015, 10:51 AM #75000 RPM
- Aug 2009
- Florence SC
- 249
Nothing screwed in, all press, outer silver looking ring is grease ring,
Set up on center of bearing & pull like HELL.
Very big slide hammer or long puller will remove.
reinstallation is easiest w/ tool, but can be installed w/ regular tools
Alignment is critical or you will learn a lot of new bad words when reinstalling the drive.
Any questions, just give me a call
Lawrence Thornton
843-617-9711
Florence SC
06-17-2015, 01:58 PM #8
06-17-2015, 05:36 PM #9
06-17-2015, 08:02 PM #10
Thank you sir for the info and the offer.
I cleaned it up real good, spent some time picking at it while shining a flas light on it and decided it is what holds that end of the bellows in place??
It has "knobs" sticking up that look like a place for a spanner to grasp to screw it out.
Hooked my slide hammer to it and it popped right out. Bearing isn't really bad but I could hear it under load and since this boat is taking us on Lake Erie....., I ain't riskin nothing!
As to the alignment, I remember well, doing many of them back in the day.
Customer brings boat in to be winterized, we pull the drive to grease the U-joints and the motor drops
I'll buy an alignment tool if it doesn't slide back in. Or grease up the splines, try it, pull it off and see where the grease shows contact w/the splines. The boat is a virgin, '86 Formula so I'm thinking good thoughts : )I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-17-2015, 08:40 PM #11
I think I know what you were seeing. the 80's MR Alpha's has those nubs cast into area where the brg goes. You should be good to go. Hope the alignment works out. Now go out and shift that thing into fwd gear before you forget.
DoktorC liked this post
06-18-2015, 07:05 AM #12I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-18-2015, 07:33 AM #13
Did mine last year (albeit a new one -'00 model). Bought a puller and worked like a champ. Just torqued it down and she popped right out. For installing, I put it in the freezer for a few hours and a quick pop had it back in..
The hardest part was getting the new bellows installed. Left me cursing and screaming. A phone call and case of Miller Lite later, it was back on. (thanks to a brother that helped me out locally).You never know what your faith is, until your faith has been truly tested.
06-18-2015, 05:33 PM #14
Yep, A bellows job can drive you to drink. I even have the Merc bellow tool. Still a pain. I don't do them anymore if I can help it. Do the bellows kits around the country all have that poison in them for muskrats? Just wondering?
DaveW
06-18-2015, 07:02 PM #15
Drive and shift bellows, no problem. A 1/4 drive impact style 5/16 swivel socket is your friend......now exhaust bellows, f those. Most of my customers get the old style exhaust tube that only connects to the transom assembly...very few complain about the extra noise. Most don't know any better as there is 2 foot of swim platform that I beat my head on at least 10 times during the job.
Mike Dowling
Labor Cost Out - Alpha Drive, gimbal bearing and U-joint replacement
By Stoker1 in forum Technical DiscussionReplies: 3Last Post: 08-03-2014, 09:53 AM -
OMC Tech: gimbal bearing install
By Whitecaps in forum Technical DiscussionReplies: 3Last Post: 10-02-2009, 09:43 PM -
Gimbal Bearing removal...
By Rusrog in forum Technical DiscussionReplies: 4Last Post: 05-14-2003, 10:16 PM
