Results 1 to 7 of 7
Thread: 15" short ram stuck up
06-01-2015, 08:07 PM #1
My trim stuck up on the ally motor runs sounds like its against stop like all way down but wont go valve stuck in the pump?
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
99 action craft flats boat
88 xr2002
90 Stv pro comp
10 mirage 1/4 master
98 mirage 1/4master
06-01-2015, 08:14 PM #2
i feel better knowing im not only person with weird problems
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
06-01-2015, 09:51 PM #3
My guess is valve stuck in the pump. "Sounds like it's against the stop" pretty much tells you that the pump is making pressure.
06-02-2015, 05:19 AM #4
Stuck valve was my first guess hoping for somthing a little more simple lol
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
88 xr2002
90 Stv pro comp
98 mirage 1/4master
06-02-2015, 07:47 AM #5
I don't know that much about the inside of those pumps but they do run both directions so there's only a relief valve on each outlet. If the seal on the bottom of the piston is blown it will allways go up. Dave
06-02-2015, 08:34 AM #6
Just looked up a diagram on the oildyne pumps there is a sliding shuttle valve in the pump that opens for the return fluid, it would make sense if that valve is stuck there would be no way for the fluid on the bottom side of the cylinder to get back to the pump. You may try cracking loose the line on the bottom side of the cylinder if there was a lot of air in the fluid, it may have expanded and locked the shuttle valve in the middle, easy enough to try.
06-02-2015, 09:56 AM #7
Gonna try to look into it today
19 bullet
82 v king
84 v king
93 stv pro comp
07 venom
80 gt20
93 v-21
89 stv procomp
97 xr 2001
89 stv pro comp
82 17 action marine
88 xr2002
90 Stv pro comp
98 mirage 1/4master
