Results 1 to 15 of 29
    minocqua, wis
    rebuilt bridgeport white smoke from exhaust black water from mid
    have a rebuilt Bridgeport ,installed on hydrostream xt ,motor was rebuilt from shop in Minnesota wont say who, I,m just the installer
    here are the results .
    hit the key and motor fired right up sounded like something amiss not running on all 6
    looked at tops of pistons some wet some not ,removed injectors as a assembly and turn key crank engine spraying into towel so I can watch 3 good 3 not good
    so I did a quick clean reinstall running on all 6 now but smoking white real bad ,and the water coming from holes in mid looks like dirt brown/black I let it run across my hand
    it looked like brown dirty water ,water from heads was clear .shut off motor there was black goo oozing from exhaust around carrier onto drive and is nasty I cannot get it off drive
    I have a 2' wide black oily stripe down my whole drive anyway I,m having owner take boat to that shop that rebuilt the motor and have them look into there work see what they over looked
    sparkplugs were new and looked like there wiped off clean after running , there are electric issues stator and rectifier also I cannot touch ,this was told to be a ready to run motor
    and they said we ran it for 1/2 hour ,would be impossible as they would of been smoked out in 5 min .
    Oct 2007
    North Port Florida
    All I can say is this. A gentleman once asked me to do a start up on a motor that was rebuilt with virtually 0 hours from out of state. The motor was dragging, distributor wouldn't move etc. I backed out. He talked me into coming back, mistake on my part. I was trying to help, it didnt end good. I wish you lots of luck. The moral of my story is, I'll never do that again.
    Quote Originally Posted by mrcrsr View Post
    and you could always add more hp!!
    There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
    Quinten
    86' Hydrostream Vking YT, 2.4 Bridgeport EFI
    (Rigging and interior in the works)
    88' Hydrostream Voyager, 2.4 200 Merc
    Boat of The Month Feb. 2009
    resto here, http://forums.screamandfly.com/forum...d.php?t=144414
    Dedicated to you Dad, I miss you! 1935-2008
    Ft. Lauderdale, Fl
    Had a lemmonrude come from up north, they said it was just serviced and had a new vro pump on it.... it would not stay running and got to the point it seized. After checking it out, found when you primed it, the fuel would fill #6 and hydro lock it....bad VRO pump..... got it running decent and all the years of carbon and oil build up ended up on our drive just like you're describing...... maybe there's a hole in the fuel pump diaphragm...............
    Ft. Lauderdale, Fl
    Another thought.... sure it's white smoke and not steam?.... brown water could be exhaust system being steam cleaned.........
    minocqua, wis
    we believe its steam washing out mid section carbon from last 20 years I should of snapped a pic it looked like a burnout contest in my drive I,m surprised nobody called fire department ,or DNR Ranger did not stop over from all the smoke
    Sep 2002
    Clean plugs is a sign of water intrusion, which could also cause the white smoke. Leaking gasket?
  7. Likes Slimm liked this post
    Ft. Lauderdale, Fl
    Quote Originally Posted by pyro View Post
  9. #8
    Aug 2009
    savannah,ga
    Pistons in wrong?...there is p,s,and an up stamped on them for a reason...just a thought but probably not the problem.
  10. #9
    Jun 2004
    port st. lucie, fl
    Sounds like water getting into the combustion chambers
  11. #10
    minocqua, wis
    still waiting for reply from shop where motor was built .
  12. #11
    Exhast divider, warped heads, bad head gskts, block needs decking?
  13. #12
    minocqua, wis
    update. motor is back at shop in Minnesota still wont run ,did a leakdown after 3/4 hours used 10 gal gas in 1/2 hr would not rev past 5000
    cyl 1 20% cyl 3 15% cyl 5 12%
    cyl 2 7% cyl 4 5% cyl 6 5%
    also has a powerhead stud came loose and wont tighten leaking exhaust and water in that area . way too rich you can see gas in water on the ground coming out of the exhaust
    owner is trying to get his $ back
  14. #13
    minocqua, wis
    update ,replaced ecu switch boxes , ,spark plug wires were wrong ones ,and fixed power head stud
    said motor not broke in yet so cant look at leakdown numbers B.S. I say ,
    so owner is running motor says it runs ok
  15. #14
    Quote Originally Posted by eli View Post
    Unless it has TiN rings can do leakdown after an hour.
  16. #15
    minocqua, wis
    basically the shop said leakdown don't work on new rings
