Results 1 to 15 of 21
    Jan 2010
    Venice, FL
    Allison Jack Plate
    Well, got the new toy mounted today. Thanks again Don! Find out how she performs tomorrow.
    Anybody had experience with one on a 15 Baja? Total of 4 1/2" setback.
    Raised the motor 1/2". Propshaft's now bout 5" below the keel. Good place to start?
    How soon til I need LWP?
    shreveport,la
    Its still pretty deep... Make sure you have a trustworthy h2o pressure gauge.. Incrementally bring the engine up until you begin to see erratic pressure readings (sucking air), then lower back down incrementally until the pick-ups are pulling in no air.. If you want that highest setting then you can plug the top one or two intake holes, or then go to a nosecone and keep going up..
    It may start to slip when coming out of the hole, over revving a bit till the bow lays over and then it will hook-up and move on just fine
    Kevin Kiser
    Jul 2009
    savannah,ga.
    You should be able to come up till the top of the lower unit barrel is even with the keel.
    Jan 2010
    Venice, FL
    I dunno Fred. Not sure how much I wanna raise it before adding a low water pickup. If you lay a straight edge on the bottom I've already got the top two intake holes exposed?
    Dec 2011
    Ludington michigan,on the shore
    Water rises as it exits the rear of the hull.Looks like you have a couple inches at least.
    Jan 2010
    Venice, FL
    Quote Originally Posted by outasite View Post
    Went up another inch. We'll see what happens.
    Sep 2010
    Townsville, Australia
    With the current gearcase/pickups you could easily run it 1 - 1 1/2" below plank (center of prop shaft to running plank).
    Looks way, way deep at the moment!
    Aug 2004
    Venice, Florida
    Time to get a LWP on that thing and let her eat. I think a lot of your handling issues will clear up when you get it set up better.
    21' Paramount
    Mercury 300 Promax
    Jan 2010
    Venice, FL
    Thanks guys. Ya I know it needs to come up. Bob's cone is on the list. Anyplace cheaper to get one than buying direct? They want a lil under $200.
    Aug 2004
    Venice, Florida
    I think I saw one sitting at Rich Junkers shop. Thinks its a TH Marine nosecone. Give him a call. He might make you a deal if you have him weld it.
    21' Paramount
    Mercury 300 Promax
    Jan 2010
    Venice, FL
    'Preciate the heads up Chris. But think I'm gonna hold out for a Bob's.
    In the mean time I went diggin through Ernie's junk pile and came up with this:
    Figgered a pressure gauge'd be a good idea. Idles at 3 psi on muffs. Is that okay/accurate? Ain't stuck it in the water yet?
  12. #12
    shreveport,la
    3lbs is plenty on the hose.. Don't rev it up hard on the muffs though..
    Kevin Kiser
  13. #13
    In post #1 it looks like the bottom of the jackplate os sticking out from the transom a bit....???
    If ya dont want to go with a lwp mite think of cilling in the top 2 holes and opening up the bottom ones and feathering the water into them..
    My 2 cents
  14. #14
    Jan 2010
    Venice, FL
    Thanks for confirming that Ted. Also been told I oughta get 10 - 12 psi at idle with it in the water. And 20 mebbe 25 at a slow cruise. Do you concur?
  15. #15
    Jan 2010
    Venice, FL
    Quote Originally Posted by roadkill636 View Post
    My 2 cents
    Not sure what you mean RK. It's flush against the transom?
    Gonna go with lwp soon's possible. Just ain't got enough jingle right now ...
