Results 1 to 15 of 107
Thread: what do i got going on here???
05-15-2015, 05:19 PM #1
I was thinking some sort of exhaust leak or something I don't know **** about OMC has anybody seen this before I clean the **** out of the boat and the motor degrease everything it looks real nice I take it out for the day and this is what it looks like when I come home it idles like **** once you get it up on a plane it runs great smokes really bad at idle
SEEBOLD CHAMPBOAT MERCURY S3000
05-15-2015, 06:08 PM #2
If it was me, I would first drop the lower unit and check the seals on the inner lower exhaust housing. The seals are kind of a pain to keep in place when you install a lower and they could have gotten pinched. If that's not it then your on to adapter plate and base gaskets. Are you getting a lot of black sludge through the prop?
05-15-2015, 06:11 PM #3
Parker looks like a bad powerhead base gasket. Check the pan base and remove the trim under the pan and check there. But something caused the idle circuit to go rich also. You wanted to clean those carbs anyway didn't ya! Seams like I do that to all my new rigs. If I lived closer I would give ya a hand I know those puppys pretty good now. Gary
05-15-2015, 06:39 PM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Looks like a lower main seal.
05-15-2015, 06:51 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Start wrenching
05-15-2015, 07:26 PM #6
05-15-2015, 07:32 PM #7
05-15-2015, 07:59 PM #8
otor is a 1987 and I don't know if the power had would even come off it's a little crusty from been running salt water its whole life when I got the boat it was sitting 12 years I went through the carburetors everything new trim motor just everything I had to do a water pump lungs I mean just went through the whole thing and I fire right now but I was running great but everytime I take it out I got this god damn black sludge the ****ing **** is like tar running down the side of the midsection so obviously I got some sort of Leak Up top but I don't even know if the powerhead would come off it's so crowded on thereI'm going to pull that little skirt thing off of there I'm already tried to tighten the power head bolts they won't tighten but I'm going to pull that skirt off decrease it real good and pressure wash it with hot water and see what I got tomorrow I'm thinking about taking a drill and drilling out the 2 half inch holes to relieve some of the exhaust pressure in the Can
05-15-2015, 08:02 PM #9
I bet drilling out those two holes in the back of the can will really help,how far do I have to drill in on those two holes do I go all the way through the tuner or just threw the can itself?the motor so it's very low on the transom so I hope it will help
05-15-2015, 08:10 PM #10
Should i drill into the tuner also ? Looks like i can drill thru the housing pretty easy , looks like i should keep drilling into the tuner also ?
Sorry guys i just dont **** about omcSEEBOLD CHAMPBOAT MERCURY S3000
05-15-2015, 08:14 PM #11
.....going to stick a half inch drill right of those two holes for the exhaust comes out underneath that little plastic caling skirt thing I'm just wondering how far I have to drill in
05-15-2015, 08:15 PM #12
god damn thing just sitS so low in the water
05-15-2015, 08:42 PM #13Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Is you drunk?
05-15-2015, 08:43 PM #14
That part is between the lower unit and tuner, just drop the lower unit and see if it is there and if the two rubber seals are there/intact/in place
05-15-2015, 08:43 PM #15
