Results 1 to 13 of 13
Thread: Hydraulic Jack Plate Info
05-14-2015, 08:38 PM #1Member
- May 2013
- Lebanon,ky
- 46
05-14-2015, 09:27 PM #2
Looks like a Detwiler what size is it 8"? does it have the pump in the plate or is it sepatate with oil lines running to the pump ( early style)
1993 Cougar 21ft MTR Superbender SHO
05-14-2015, 09:30 PM #3Member
- May 2013
- Lebanon,ky
- 46
Its the early style. Good or bad??? Any idea what its worth? not sure about size.
05-14-2015, 09:38 PM #4
measure from the surface that bolts to the transome to the surface that bolts to the motor. do you have the lines and pump? does it work? no leaks?
05-14-2015, 09:41 PM #5Member
- May 2013
- Lebanon,ky
- 46
Everything is there in great shape and works perfect.
05-14-2015, 09:48 PM #6
they are a good solid plate. not sure what its worth. Are you selling it?
05-14-2015, 09:50 PM #7Member
- May 2013
- Lebanon,ky
- 46
It measures 11 1/2" from the surface that bolts to the transom to the surface that bolts to the motor.
05-14-2015, 09:53 PM #8
going to a different size plate?
05-14-2015, 09:58 PM #9Member
- May 2013
- Lebanon,ky
- 46
No bought a boat with this one on it. Wondering what its worth. So would this one be a 11" or 11.5 " set back? Never seen one this size.
05-14-2015, 10:05 PM #10
it would be a 10" or a 12" ,didn't think they made one that big. is there a part number on it?
Steve1993 Cougar 21ft MTR Superbender SHO
05-14-2015, 10:07 PM #11Member
- May 2013
- Lebanon,ky
- 46
No part number I have seen.
05-14-2015, 10:18 PM #12Member
- May 2013
- Lebanon,ky
- 46
Looks like there may be a part you can take off to reduce setback.
05-14-2015, 10:19 PM #135000 RPM
- May 2014
- NH
- 170
- 27
- 37
- 16
Something around a 10 inch isn't uncommon. I paid $700 new for the high speed CMC 5.5 inch I bought a year ago. The 10 inch didn't add much cost but I didn't want to commit to that distance - I actually have 9.5 inches of setback after using spacers.
At the time there were some models on Ebay for about $550 new old-stock that had the non-integral hydraulics - to me I figured it'd be best to get the latest design in a commonly found brand in case the thing gave me trouble later.
I'd say what you got is worth $300 if it's in good working condition.
JonLast edited by leaky; 05-14-2015 at 10:22 PM.
