Results 1 to 12 of 12
    Sep 2014
    Pa
    Checkmate Enchanter 200 merc
    Just curious if anyone else has the same boat and what do they run? Im running a 24 turbo on it and its turning 5500 rpms at 61 mph. Dont have a jackplate/ setback. Does this sound right? I also ran a 23 cleaver but spun 6500 which was too much at the same speed. Ive heard most guys run 68-70 mph with a jack plate and set back. Is that really the 7-8 mph im missing out on?
    Oct 2010
    Greenwood Lake, NY
    You can look on the Checkmate-Boats page for more info but a Cleaver isn't going to work well on that hull. A Chopper should work well for high speed. You can definitely use some setback but unless the transom is beefed up some I wouldn't go more than 6 inches back.
    I was going so slow I almost crashed. - JamesGang
    1978 24 Superboat - 250 EFI
    I tested lots of props (chopper, cleaver, laser, high five, etc) and by far the best on my 20' Enchanter / 200 Merc was a plain old 24 Michigan Wheel stainless 3-blade prop... but the only way to run in the mid-70's with 200hp was to run it with nose way up in the air, throwing a huge rooster tail.
    I plugged the UPPER two holes on the lower unit and ran it about as high as it could go without losing pressure... I just had a fixed setback spacer, I think 4" or less.
    With ~240hp it ran high 70's with four people... and it ran much flatter, using much less trim.
    Prop looked just like this one: http://www.ebay.com/itm/321739344844
    Oct 2010
    Greenwood Lake, NY
    It's the UPPER holes in the lower you need to plug if you are going to run the motor high up without a low water pick up. On my 250 EFI there's 8 holes on each side and 4 on each side are plugged.
    Quote Originally Posted by JohnR View Post
    Yes, you're right. It's only been 20 years... can't believe I got that mixed up.
    Sep 2014
    Pa
    Thanks guys. Im gonna try another prop this weekend. Maybe my next step is a jackplate with 6" setback, i dont want to get carried away with reinforcing the transom.
    Oct 2010
    Greenwood Lake, NY
    It happens Dave.
    Get that motor up so the shaft is just a couple of inches below the pad and go from there.
    Oct 2010
    Greenwood Lake, NY
    Where in PA are you tunnelflite?
    Jun 2012
    Vergas mn
    83 enchanter with a healthy 2.4 200 6" manual JP top holes plugged, i was trying for 2" below pad but never got that high without losing water psi, I think 2.5"-3" was all the higher I got. 25 pitch trophy plus I believe 6400 rpms 69 GPS just me low on fuel, lots of testing, $, research, was it worth it= no. I bought a cougar 19 now I can switch boats and go 110, my 23p high five never comes of my enchanter anymore. Be sure you get a water psi gauge and some better reeds if you are going to be running over 6k rpms. Good luck and have fun!
    1990 Cougar 19/260 2.5
    1997 ski brendella
    08 2100br 300xs
    Sep 2014
    Pa
    I live a out side of philly but boat in the delaware river. yeah i hear ya 12pack, im looking to get a hydrostream venus if i ever come across a nice one. I like having a smaller boat with a cuddy at least for now. Thanks for all the advice ill eventually get a jack plate and fine tune it.
    This was the fastest run (while I had it anyway) with the 200hp motor.
  12. #12
    Jun 2012
    Vergas mn
    Also I will say that adding the jackplate gave the boat a way different feel, much better handling. That is a positive side to all that I did, it is definitely a good upgrade. Didn't mean to be all negative.
    1997 ski brendella
    08 2100br 300xs
