Results 1 to 9 of 9
    Aug 2009
    ca
    280 lazy ides rough dies when puts in nutreal
    I have a 280 that runs rough won't idle dies when I shift it into neutral. It seems like it want to run at speed with a 26 pitch prop but won't pull a 30 like it used to. Fuel pressure is good new plugs ql77cc. Water pressure is 15 lbs about 4000 rpm tps is at 801 I get a misfire on number one occasionaly. It just sounds like **** at idle. Changed filters. Coils are dry swapped ecu reeds are good compression is 140-145 across the board.seems like it won't go over mid 6000 rpm. One of the ecu' was in breakin mode and I thought that was gonna be it but didn't really fix it
    Jan 2008
    eatonton ga
    Check tps
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
    Jun 2012
    Indiana
    Have you ever had the injectors cleaned? Also check the air temp sensor, my 280 had similar symptoms and needed a new one.
    How many hours on the motor? Done a leak down test?
    Aug 2009
    ca
    Ok leak down was with in 10%. Tps is at 801. The ddt says air temp sensor is good.
    Jan 2003
    aalsmeer
    you wrote you had a misfire
    did you try swapping the coils?
    could not read that
    did you also try a fresch set of spark plug?
    Aug 2009
    ca
    Ok so now I switched out the injectors and I got my idle to come back and seem smooth. I'm starting to think I got the water pressure sensor mixed up with one from a compleatly different carb motor. Does anyone know the correct part number for the water pressure sensor and it just seems lazy and lethargic still
    minocqua, wis
    10 % leakdown across is getting tired
    Jun 2004
    port st. lucie, fl
    also, is the map and fuel pressure barbs in the plenum clear? they get clogged and gummed up, and map sensor no longer gets an accurate reading. see if you can blow air thru the fittings. as said, 10% leakdown means it is kinda due for a rebuild. bad or wrong water pressure sensor usually will set a code and alarm, and bring on rpm limiting.
