Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
    Apr 2015
    Sydney Australia
    STV with a 250ho ETEC
    Hi all
    Was wondering if anyone could offer some advice please? I am pretty new to high speed boats I live in Australia and own a STV with a 250ho etec on it. I am having problems trying to find a prop to get it to do decent speeds.
    The engine has the M2 gear case with 1.85:1 ratio. I run a Detwiller hydraulic jacking plate so can adjust engine height on the move. I have tried all sorts of props different diameters and pitches ranging from 28px141/2 diameter to 34px151/4 diameter at different engine heights and trims. The best prop I own for it so far is a 34px141/2 Hoss style chopper it runs 89mph on the gps and hits the rev limiter. The best speed I have seen on the gps was when I borrowed a 32px141/2 4 blade Et cleaver it ran 92mph and hits the rev limiter. I have just installed a nose cone to my gear case and hope that it might help. I appreciate any advice.
    Cheers Chris
    Jul 2001
    Paris, France
    Hi Chris welcome aboard. You'll get lots of help here. How many STV's in Australia ? Any pics ?
    ARGO Cat 18'
    Mercury 2.4EFI/CLE
    If it's not a cat it's a.............dog ?
    Apr 2015
    Sydney Australia
    Hi thanks
    I know of 8 stv's that are here in Australia but would say there would be more out there. Will try to post some pics soon.
    shreveport,la
    You need more gear than a 1.85. Does OMC offer something in the 1.60's?
    Erik Kiser
    Ontario, Canada
    Quote Originally Posted by stv250 View Post
    Hi all
    The engine has the M2 gear case with 1.85:1 ratio. I run a Detwiller hydraulic jacking plate so can adjust engine height on the move. I have tried all sorts of props different diameters and pitches ranging from 28px141/2 diameter to 34px151/4 diameter at different engine heights and trims. The best prop I own for it so far is a 34px141/2 Hoss style chopper it runs 89mph on the gps and hits the rev limiter. The best speed I have seen on the gps was when I borrowed a 32px141/2 4 blade Et cleaver it ran 92mph and hits the rev limiter. I have just installed a nose cone to my gear case and hope that it might help. I appreciate any advice.Cheers Chris
    Hi Chris - what does your rig weigh?
  6. Likes duckrazee liked this post
    lost in Tennessee
    A cleaver would be your best bet
    I have been 103 on a stock m2 case with a 15x34 et on rev limiter. You need to get your slip down. Do you have a torque tab?
    we have converted a few to 1.62 sport masters and it's about the only way you can bolt on 15-20mph gain.
  9. #8
    Shreveport, La.
    Hi Chris. If you want to go considerably faster get a Mercury.
  10. #9
    Sarasota, FL
    a nose cone with low water pickup will help you increase you're speed because you can get the prop shaft higher out of the water than you were previously. Please post your numbers after you try it with the nose cone and the prop shaft an inch above the pad
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  11. #10
    Jan 2008
    eatonton ga
    Quote Originally Posted by Hot Shot Merc View Post
    Yup what he said
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
  12. #11
    Sarasota, FL
    I also agree that more gear is needed as well to try and keep off the limiter. What rpm is the limiter on that motor?
    Rob Lankford
  13. #12
    6250 limiter
    the cone will help you but you will be able to put a 36 on limiter so your 34 will get there even easier.
  14. #13
    Jun 2008
    5 Thread(s)
    Chris, my STV with a 250 E-TEC runs best with a 14.5 x 34 Mercury cleaver. You may want to look into running an L2 Lightning gearcase with a low water pick-up nose cone and a 1.71:1 gear ratio. They are getting hard to find as they are no longer in production. A Mercury Sportmaster with a 1.62 ratio also makes a good choice. Transom height is also crucial to getting the most out of that big Evinrude. Keep us posted on your progress and include some pics.
    Karl
    16' Samurai 135hp Johnson sold
    16' Banshee 135hp Johnson sold
    16' Action Evinrude Strangler sold
    21' Olympia 2.6L Johnson sold
    18' Critchfield 2.6L Evinrude sold
    20' Sanger 3.6L Evinrude V8 sold
    19' Action 2.6L / 3.6L V8 Evinrude sold
    19' Action 2.7L Evinrude sold
    19' Action 3L Johnson sold
    25' Action 3.6L Evinrude V8 sold
    25' Action Twin 175hp Johnsons sold
    25' Action 4L Monty V8 sold
    18' Action 115HO E-TEC sold
    19' Action 250HO E-TEC sold
    23' Action 250HO E-TEC
    STV R/R Monty 250HO E-TEC
  15. #14
    port saint lucie fl
    SANTAFE Really!!
  16. Likes Smoking Joe liked this post
  17. #15
    Feb 2007
    lily lake WI
    He could go an easy 125 + with a bump up rev limiter to 7300 rpm but that ship has now long sailed away post a picture of the boat it's nice to see go fast boats all over the world
