Results 1 to 8 of 8
04-25-2015, 06:30 AM #1
OH NO I've gone over to the dark side! 1988 25SG Yammy ?s
Yup I did it. Bought a rice burner... never thought in 61yrs I'd do it!!! Its a twin carb 2 cyl 25hp short, tiller with oil injection I couldn't pass up for my 11ft SLT. Should I remove the oil injection (that I do to other motors I spin up) or is it reliable so I could add some oil to fuel tank. I have been lookin for more info as injection ratio and max rpm. I will be using 91 oct ethanol free fuel and Klotz syn. oil. Any info and or suggestions would be apreciated. Thanks Gary
04-25-2015, 06:54 AM #2
The oil injection itself is a very reliable system...my only question is what ratio those little motors are? If it's 100:1 than you need to add oil if you are going to rev it.
i always liked the twin carb 25..'08 SRV
Yamaha 3.1 Phase III
04-25-2015, 07:02 AM #3
According to the google it is a 100:1 motor....which works fine if you're running it as a 25 is meant to be.....but if you're going to run it hard than mix the tank 100-1 as well...IMO....
'08 SRV
04-25-2015, 07:34 AM #4
Thanks Dok Just the info I am lookin for... Will look up the max rpm and since the prop is surfaced on my SLT ( 20"transom) I'm gonna run a high pitch (saw up to 14") cupped prop. I am really impressed with the throttle response these little guys have and shes a looper (new to me to play with) and at 104lbs light enough for my rig.
04-25-2015, 07:55 AM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
ZINg, ZINg, okay lets go.
11-27-2015, 07:20 PM #6
Hey Doc (or anyone else that may know) Do you have any idea how much I can cut this head or where to look for this info.BTW this little 2 carb cutie runs sweet and will turn over 6K all day! Gary
11-27-2015, 08:56 PM #7
Obviously your gonna have to find someone else to hang with at Jasper
11-28-2015, 07:51 AM #8"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
