Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
    Dec 2003
    rockford ill.
    looking 4 info. on omc mad efi
    Why did they stop it?strictly merc. now?i thought mad efi was the best sytem for omc .
    Gothenburg, Sweden
    Quote Originally Posted by bigbore View Post
    Because it was not selling
    Brucato was better, but it was not selling either.
    Calgary, Alberta
    If you really, really want the basic MADEFI for a V4 you can still get a similar setup. The MAD is the outboard version of the Simple Digital Systems (SDS) ECU, which is still going strong - made by Racetech in Alberta, Canada. They will be happy to sell it to you but won't be of much help on mapping/configuration since they're 4-stroke guys. If you meant the MAD OZ front half I don't think they make it for the V4 anymore.
    Matt
    lindsay on. canada
    find a front half off a e-tec and run it off a Bracato box .
  5. Likes powerabout liked this post
    Dec 2003
    rockford ill.
    its a v6 225,but I was thinking that setup rocked,the thing I like about mad efi setup was varitable control knob 4 fuel flow.
    lindsay on. canada
    Bracato efi box has the same control , you will be much happier .
    Jun 2001
    South East Georgia
    Brucato is what I got on my OMC.
    I know somebody that has a Mad Efi /SDS that might be interested in selling it.
    TMc
    1984 Allison XR2002
    1987 2.7 Fuel Injected Evinrude
    16" Taylor mid
    Brucato ACU.
  9. #8
    Dec 2003
    rockford ill.
    also taylor's has sds control box u can mount for mapping
  10. #9
    8 Post(s)
    If you do all the hardware I'm sure Brucato will supply the pack with base map?
  11. #10
    Jul 2008
    Eutawville SC 29048
    803-823-2121 Mitch has two complete mad efi kits
    1995 STV RR 150 hp Super Mag
    1978 16' Allison 90 hp Yamaha
  12. #11
    Gothenburg, Sweden
    The MAD system only uses throttle position, not a mass airflow sensor.
    That means that you will have to change your curve if you use another propeller or add another 30 gallons of fuel.
    If all you are doing is drag racing with the exact same setup, the MAD will do the job. Otherwise, it will not.
  13. #12
    8 Post(s)
    or change altitude or hot humid day to cold day.
  14. #13
    Dec 2003
    rockford ill.
    I was thinking fuel knob adjust flow for any condition.makes a big difference min-to-max on mine.
  15. #14
    Gothenburg, Sweden
    I suppose that if you have a midget in the boat who has access to readings from an airflow sensor, EGT and ideally an oxygen sensor, and who is able to turn that fuel knob really fast, you can make MAD EFI work under any condition.
    If the midget falls asleep, you will need a couple of new pistons.
  16. #15
    8 Post(s)
    MAP and temp are the only way to go on an outboard once its on the water.
