Results 16 to 30 of 45
    Dec 2003
    rockford ill.
    ok,let me see if I can get this straight,u guys are talking about manifold air pressure sensor,mass air flow sensor,and mapping the ecm,map and maf sensor q's in with 1 journal(meaning 1 cylinder,being that's the way these block';s are designed)that does not compensate for the other 5 cylinders,so that being said,mapping the ecm for whatever fuel curve the block is ported for is the only way to hit fuel curve on the head,plus the fuel knob that control's more or less fuel variences to different situation that would be more than enough if ecm is mapped correctly from the start,i like the mad efi setup.
  2. #17
    8 Post(s)
    There are no MAF sensors used on marine engines ( deemed too dangerous), nice tool on the dyno though and other than egt you cant put anything in the exhaust of a 2 stroke.
    Hence after you have visited the dyno room your system will need to reply on MAP and temps to work on your boat, so make sure they are included on any system you choose.
  3. #18
    Dec 2003
    rockford ill.
    I've been through this before somewhat,the easiest n beast way to monitor it is head-temp guage on each cylinder that can b done for about 150.00-200.00 dollars,n a custom pod mounted on dash.
  4. #19
    Gothenburg, Sweden
    Yamaha has used O2 sensors on 2-stroke outboards.
  5. #20
    Gothenburg, Sweden
    Quote Originally Posted by bigbore View Post
    The MAD curve is only based on throttle position and rpm. That does not work in most real life applications.
    You need a system with a MAP sensor. That is what Mercury uses.
  6. #21
    8 Post(s)
    [QUOTE749430]Yamaha has used O2 sensors on 2-stroke outboards.[/QUOTE]
    Wasnt it on one model for one year and lots of trouble?
    I admire the attempt though.
  7. #22
    Dec 2003
    rockford ill.
    Just dont understand how mass air flow for 1 journal is consistent for the other 5.
  8. #23
    8 Post(s)
    Just dont understand how manifold air pressure for 1 journal is consistent for the other 5.
    You either run an airbox like 260/280 Merc or you have to make a manifold and collect all the signals and that is from in front of the reeds of course.
  9. #24
    Dec 2003
    rockford ill.
    Hang on i'll look at brucato's intake,this is what i'm used to.Attachment 318666
  10. #25
    8 Post(s)
    Quote Originally Posted by StratosVT View Post
    Yeah...ah NO! The MAP sensor is not going to compensate for air conditions or anything else. It's just an alternative way of measuring throttle opening by air pressure instead of potentiometer. Most everyone who uses Motec and other aftermarket ecus use TPS.
    I thought some packs can do an air density calculation from the map+air temp+rpm+ve table= density calculation
  11. #26
    Dec 2003
    rockford ill.
    My mad's got a ambient air sensor on the intake manifold.
  12. #27
    Mar 2003
    Belvidere IL, FARM
    Quote Originally Posted by Markus View Post
    I suppose that if you have a midget in the boat who has access to readings from an airflow sensor, EGT and ideally an oxygen sensor, and who is able to turn that fuel knob really fast, you can make MAD EFI work under any condition.
    If the midget falls asleep, you will need a couple of new pistons.
    He has gay midgets in there, the problem is they start fooling with his balls and forget all about turning the knob.....or at least the correct knob, BigBore, that boat looks filthy, get her cleaned up....
    God, Country, and Fast Boats
  13. #28
    May 2001
    Hickory NC
    Yamaha had the o2 on the intake
  14. #29
    Dec 2003
    rockford ill.
    Sure am happy to see everybody out the wood-work,thanks 4 replying guys.
  15. #30
    Dec 2003
    rockford ill.
    bigore'll dust his boat
    As soon as he's off probation.
