Results 1 to 8 of 8
04-15-2015, 09:53 PM #15000 RPM
- Jul 2008
- Portland Oregon
- 100
Bolt torque on 2.5L Exhaust divider.
My manual shows 20nm or 180ft in for the bolts on the exhaust divider. I managed to strip the first two bolts into the block and didn't get anywhere near 20nm. I thought my wrench was off, but tried my spare and same issue. Is this a common problem? Is that torque right? Same bolts that came out. What am i doing wrong?
04-15-2015, 10:06 PM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
16/18 inch pounds for fishing motors, hipo use 20 inch pounds
04-18-2015, 07:53 AM #35000 RPM
- Jul 2008
- Portland Oregon
- 100
04-22-2015, 02:17 PM #45000 RPM
- Jul 2008
- Portland Oregon
- 100
Not sure if anyone else will stumble on this... My block looks like it already had inserts on many of the middle bolt holes. Not sure if this was a factory issue or someone changed previously... I bought some of the (very expensive) 650 degree locktite and new inserts and plan to replace the existing inserts and use the high temp loctite.
04-22-2015, 09:27 PM #5Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
probably somebody reading same info heavy hands dont fare well on these alum blocks i paid my share of dues
04-25-2015, 11:55 AM #6Junior Member
- Aug 2014
- Houma
- 22
Is it possible to crack the block of a promax before stripping out the powerhead base bolts..or would the threads give first..
04-25-2015, 02:24 PM #7Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
It is possible to crack it
Erik Kiser
04-25-2015, 04:16 PM #8Junior Member
- Aug 2014
- Houma
- 22
cmb sorry for jumping in your post like that..but thanks guys for the feedback..
