Results 16 to 30 of 35
Thread: Buying latham
    Daytona Fl.
    7 Post(s)
    I'm not sure which Charlyn, but I know the pumps run continuously. I put one in a 30ft Liberator with the IMCO power assist.
    Boat Delivery available
    Things owned. NOTHING!!
  2. #17
    Aug 2005
    Pembroke Pines , Fl
    Quote Originally Posted by aggiestckl View Post
    Do you know what type of Charlynn open center helm to use? Will it work with a Verado pump constantly running?
    I would be carefully with running a verado pump on a single opti. With the 55 amp alternator it may not keep up with the draw and will give low voltage alarms. If u run mostly cruise and higher rpms u will be ok. Any long idling and u will see battery voltage drop down below 11v
  3. #18
    Mar 2011
    Up North
    How many amp is 300 Verado alternator?
  4. #19
    Mar 2011
    Up North
    How many amp does sea star unit draw
  5. #20
    FOR what its worth Im using sea star 2.4 helm on marine machine ram and it works great varry easy to stear
    i have spare brand new one has to be unbalanced ram
  6. #21
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    The Verado alternator is 70A, and you can hear the engine drop from the load of the variable speed power steering pump. The Verado pump senses load, and speeds up, runs slower if not needed.
    A problem is only a problem when viewed as a problem...
  7. #22
    Mar 2011
    Up North
    Is larger alternator possible on opti
  8. #23
    Sep 2010
    north battleford saskatchewan canada
    Hi Glen, According to the Seastar owners manual , Max current draw is 50 amps-- typical current draw is 3 amps. The wiring harness it comes with utilizes #10 wire. Hope this helps. My pump is a PA1315-2. Bob Cruse.
  9. #24
    Jul 2004
    Connecticut
    Quote Originally Posted by merctech5591 View Post
    Excellent point and others have experienced this as an annoying problem.
  10. #25
    Mar 2011
    Up North
    A 300xs alternator lists at 60AMP and the Verado 300 list at 70AMP.. Is there that much of a difference?
    I am running no music, etc.. Just a vessel view, one GPS Speedo and this pump.. I plan on using a lightweight lithium 1000CCA or better race car style battery.. Minimal idle but its unavoidable in some situations
    Are there going to be any adverse affects of buying a high output alternator, buying a replacement alternator and having it rewound for higher output, etc?
  11. #26
    Jul 2004
    Connecticut
    Quote Originally Posted by WILDMAN View Post
    I believe the IMCO power assist pump draws 66amps at peak.
  12. #27
    Jun 2011
    South FL
    Marty at Diamond Marine can probably order it for you, or call Tom at Latham like someone previously said. I was just there last week getting a leaky ram repaired. It's not cheap but I sat in Tom's office twice and had him explain the bleeding process to me, some info on the ram and my setup, talked one-on-one with the tech who repaired the ram, and the ladies in the office were pleasant too. Turn around time was like 2 days.
    2004 Deep Impact 36 Triple 300 Verados
    1998 Donzi 35 ZFC Triple 300 Verados FOR SALE
    1989 24ft Skater, Twin Diamond Marine 280's with Diamond Tuners, 34p Cleavers. A few pieces of JL Audio equipment.- SOLD
    1988 18ft Talon- SOLD
  13. #28
    Aug 2012
    Tenkiller Lake, OK
    Glenn, My Verado pump uses a 50 AMP fuse which should be sized at least 125% of the full load (start-up) amp draw, which would be 40 amp maximum amp draw at START-UP. Running load will be a fraction of the 40 amp load. I know that I am running two Opti's, but I have limped back for approx. 30 minutes on one engine with the power steering running after an engine failure with NO issues at all! I think that you are safe with the Verado pump and one opti, just make sure that your batteries are topped off before your runs so that your alternator does not have to try to charge batteries and run the pump at the same time. David
  14. #29
    Mar 2011
    Up North
    Dave thanks for the msg.. Got your voicemail.. I will snap some pics once its installed
  15. #30
    Mar 2011
    Up North
    Latham won't sell direct. I'll try Marty at Diamond
