Results 91 to 94 of 94
04-12-2015, 01:33 AM #91
I have nearly completed a Wellcraft Nova 230 XL rebuild, took the old sterndrive out and set it up for a Evinrude V8 outboard mounted on a pod. To balance the boat I put water into containers to the same weight as the engine and all other gear which would be loaded onto the transom and inside the rear of the boat. We then slung the boat on a single sling to find the COG. This is the correct way to balance a boat. We moved the weight in and out till we got it to the correct spot. The result was 20 inches of setback, total. You have two engines and considerably more weight than I have on mine. I would suggest that you should be bolted directly to the transom or with minimum setback jack plates. I agree with Revolution141, 31 inches is way too much. When you sell the pod you can put the money toward the jack plates.
Wellcraft Nova 230 XL, 300hp Johnson.
Seahawk 45 Sport Fisher, twin 306hp Volvo.
Steadcraft 28, Yanmar 300hp. Sold.
Markline 800, Volvo 300hp. Sold.
Haines Hunter V19, Volvo 170. Sold.
16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
10-20-2016, 05:34 PM #92
Whatever happened with this thread, ever get the problem resolved?
SlimmHire the handicapped, we're fun to watch
10-21-2016, 02:55 AM #93Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Put the engines on the transom and enjoy boating.
10-21-2016, 05:59 AM #94"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
Slimm liked this post
