Results 1 to 14 of 14
    Florence, SC
    Cool Can I get some 2.4 Feedback?
    I lost a few holes today...
    Using Klotz with Premium fuel, High Five prop turning 6200 rpm on the high side... she let go while cruising nice at 40 mph at 4000 rpm.
    Thoughts? Suggestions?
    Here is the Google Drive with the images.
    https://drive.google.com/drive/u/0/#...kFYdUktS1VDdGs
    Attached Thumbnails Attached Thumbnails 20150405_203836.jpg   20150405_203903.jpg   20150405_204245.jpg   20150405_204228.jpg
    Western Pennsylvania
    I'm no expert, but if the cylinders and pistons are somewhat oily yet I would guess overheated.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    minocqua, wis
    Quote Originally Posted by Euroski View Post
    heated for sure when 2 go down
    What's imprinted in the top of the piston... looks too "square" to be a ring retaining pin or a needle bearing? Almost looks like the ground strap from a spark plug?
    Florence, SC
    It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
    David "Tango" Wilks
    Current boats: (Not All Running...LOL)
    18' VT-Rocket Bass Boat: 2.5L 280 Mercury
    21' Eliminator Daytona: Stripped and Possibly For Sale!
    24' Skater: Uncut, Not Rigged and Possibly For Sale!
    30' SeaRay 290 SunSport SLX: twin 3.0L Duramax diesels & Bravo3 drives
    52' Sunseeker Predator twin Volvo-Penta IPS900 diesels
    Houston, TX
    [QUOTE=Tango;2743885]It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
    Sorry about your motor, that sucks!!! Please do follow this to the end and try to let us know what happened. I have a 200/2.4 and dang sure dont want the same. Good luck.
    Houston, TX
    What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?
    Florence, SC
    QUOTE=rgsauger;2743891]What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?[/QUOTE]
    Motor lost power but can be turned by hand and restarted... I elected not to push it so I immediately shut it down, got a tow back to the trailer and pulled the heads. The heads look clean save for one little ding by the tiny square object. They'll be easy to clean up. I'll take a pic of the heads tomorrow.I
    David "Tango" Wilks
    Pekin, IL
    Are those pics representing 3 holes or 2.
    Rock
    Team Junk
    Florence, SC
    Attached are the Head pics.
    Thoughts? Sugesstions?
    I am now inclined to believe the ring let go.
    Attached Thumbnails Attached Thumbnails 20150406_103704.jpg   20150406_103644.jpg   20150406_103634.jpg   20150406_103537.jpg   20150406_103502.jpg
    David "Tango" Wilks
    Pekin, IL
    Since the port side seems to be the issue I might consider the switch boxes. Looks like some early stage detonation on the piston without the square dents. JMO>
    Rock
    Team Junk
  12. #12
    Is there a piece stuck in the head yet?
  13. #13
    Florence, SC
    yes, there is.
    David "Tango" Wilks
  14. #14
    Man. this is like pulling teeth.
    You might poke/pull it out and see if you can figure out what it is and where it came from, it might give you a pretty good idea how expensive it will be to fix.
