Results 1 to 14 of 14
    Camden, SC
    Cool Can I get some 2.4 Feedback?
    I lost a few holes today...
    Using Klotz with Premium fuel, High Five prop turning 6200 rpm on the high side... she let go while cruising nice at 40 mph at 4000 rpm.
    Thoughts? Suggestions?
    Here is the Google Drive with the images.
    https://drive.google.com/drive/u/0/#...kFYdUktS1VDdGs
ID:	317602   Click image for larger version.
ID:	317603   Click image for larger version.
ID:	317604   Click image for larger version.
    Western Pennsylvania
    I'm no expert, but if the cylinders and pistons are somewhat oily yet I would guess overheated.
    http://www.stvowners.com
    2003 Cougar 22MTR w/300xs x 3
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    minocqua, wis
    Quote Originally Posted by Euroski View Post
    heated for sure when 2 go down
    Juneau, WI
    What's imprinted in the top of the piston... looks too "square" to be a ring retaining pin or a needle bearing? Almost looks like the ground strap from a spark plug?
    Camden, SC
    It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
    Houston, TX
    [QUOTE=Tango;2743885]It has surface gap plugs... motor had plenty of water pressure and was not hot. I will pull the front half next week.
    Sorry about your motor, that sucks!!! Please do follow this to the end and try to let us know what happened. I have a 200/2.4 and dang sure dont want the same. Good luck.
    Houston, TX
    What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?
    Camden, SC
    QUOTE=rgsauger;2743891]What do the heads look like? Snap a pic of them too? Did she seize or smoke the rings?[/QUOTE]
    Motor lost power but can be turned by hand and restarted... I elected not to push it so I immediately shut it down, got a tow back to the trailer and pulled the heads. The heads look clean save for one little ding by the tiny square object. They'll be easy to clean up. I'll take a pic of the heads tomorrow.I
    Pekin, IL
    Are those pics representing 3 holes or 2.
    Rock
    Team Junk
    Camden, SC
    Attached are the Head pics.
    Thoughts? Sugesstions?
    I am now inclined to believe the ring let go.
ID:	317614   Click image for larger version.
ID:	317615   Click image for larger version.
ID:	317616   Click image for larger version.
ID:	317617   Click image for larger version.
    Pekin, IL
    Since the port side seems to be the issue I might consider the switch boxes. Looks like some early stage detonation on the piston without the square dents. JMO>
    Rock
    Team Junk
  12. #12
    Juneau, WI
    Is there a piece stuck in the head yet?
  13. #13
    Camden, SC
    yes, there is.
  14. #14
    Juneau, WI
    Man. this is like pulling teeth.
    You might poke/pull it out and see if you can figure out what it is and where it came from, it might give you a pretty good idea how expensive it will be to fix.
