Results 1 to 14 of 14
03-25-2015, 04:12 PM #1
Seastar pro on Mercury 300xs. help?
Hi guys..
i have switched my yamaha engine (250hpdi) with an 2011 mercury 300xs opti.
when i was going to put the seastar steering back on i noticed that the tiller bolt is too "thin" for the hole on the merc.
am i missing a bushing or is it supposed too be a bigger bolt there? but with a bigger bolt. it won't fit the steering..
any ideas?
03-25-2015, 04:20 PM #2
Any pictures?
03-25-2015, 04:25 PM #35000 RPM
- Oct 2010
- Seaford, NY
- 708
- 41
- 18
That sounds pretty important, and deadly if wrong, I would call seastar directly..
03-25-2015, 04:33 PM #4
not at the moment.. the lever that coming out directly in the front of the engine.. right under the cowling.. where you mount the front steering has a too big hole for the bolt that fits the steering.. if i have the time I'm going too take some pictures tomorrow, the boat is still in storage..
03-25-2015, 04:55 PM #5
could this be the kit I'm missing?
http://www.boatstoreusa.com/hydrauli...slide-plate-f/
03-25-2015, 05:30 PM #6
03-25-2015, 07:12 PM #7
Posed to be the same one according to the manual. part# 113225
Whoops. Sorry bout the upside down pic ...'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
03-26-2015, 10:42 AM #8
anyone having a picture of a 300xs with this kind of steering.. ? want too see if they have used the tiller arm "as is" or if they have mounted a bracket at the end of it with a another hole for this bolt..
03-27-2015, 03:26 AM #9
What cylinder do u have? Mine is the HC6345 and i took my pro max off and bolted the 300 xs right up. The bolt threads in if im not mistaken with a nut on the bottom. I'll look and see if i have a pic, if not I'll take one today.
Gary
03-27-2015, 03:33 AM #10
03-27-2015, 03:51 AM #11
03-27-2015, 04:00 PM #12
03-27-2015, 04:35 PM #13
Thanks! I have done mine exactly the same way.it has too be a wrong bolt. It is a arp bolt, maybe it is in mm? (Yamaha) you have the 3/8 bolt, right?
03-27-2015, 08:30 PM #14
Yes. 3/8-24 threads if im correct.
