Results 1 to 3 of 3
Thread: turn fin?
    Massachusetts
    turn fin?
    Hey everyone
    I'm looking for a cheap turnfin I can use on my 38" outrigger.
    I was thinking about making one...has anyone made there own before? What would I make it from? How thick/thin?
    Thanks for any help!
    -Josh
    1989 Hydrostream Vector "Spongebob" 78mph
    1980 Hydrostream Vector "Ole Blue" 104mph
    1982 Allison GT20 "Red Eagle" 92mph
    1977 Hydrostream Viper "Hornet" 105mph
    1990 Mirage Jaguar 106mph
    1989 Hydrostream V-King YT "White Lightning" 91mph
    1991 Stv Procomp "$hitbox" 90mph
    Jun 2009
    Bristol, Connecticut
    1/6" -1/8" thick aluminum 6061, you might want to bend or curl the turn fin. Do you know how to find the center of gravity of the boat? and if you do put the trailing edge of the turn fin right at the center of gravity. Keep in mind the tun fin will need to be positioned correctly to the water surface and you should have about 2.5 inches in the water for your small nitro (below ride pad of the sponson) If you go on intlwaters.com you can probably find a cheap turn fin used in great shape for like 35 bucks. Probably worth it if you haven't made one before. I get my gas rigger turn fins from a guy in Canada they are like $100 each
    Riggers are a lot of fun, but take a little knowledge to get them running correctly
    Jun 2009
    We run in Warwick on Saturday during the spring summer and fall, we can really get you goin good
