Results 16 to 20 of 20
Thread: Fuel Pumps with lift capacity..
03-06-2015, 04:24 PM #16
The Holley pumps are a sliding vane type pump and are made to "push" fuel rather than "draw" fuel. They may develop a little negative pressure on the intake side but I don't think there is enough "vacuum" to lift fuel 20 inches or so.The red holley may have closer tolerances than the blue but neither are designed to lift ( read the small print). I ran a blue Holley once and found it would not lift the fuel 6 inches. When mounted below the tank it performed as advertized--however when allowed to "sit" for a period of time, some of the vanes stuck and would not extend to make a seal. I would have to throw my hat in the ring for Carter, however, I have run a FACET High Performance Pump (21/2-9PSI) for the last 4 years and carried 2 spares, just in case-never had to use either of them. Also, they are made right here in Southern California. Go to Google, Facet Gold-Flo fuel pump advertizes 24 inches of dry fuel self priming lift. I'm not sure Carter can guarantee the same Rod
03-06-2015, 05:55 PM #17
If you have a primer bulb in-line after the pump, I don't see why you could have any problem. I run a Mallory 140 at the recommendation of a well known, reputable, hi-perf OMC mechanic for a modified looper(S. Jenkins). I pump the bulb to prime the pump. Problem solved. Never had a problem using a Carter with stock 225 in the same configuration.
03-06-2015, 08:36 PM #18
I have a Holley Red that I use in the shop for sucking old fuel out of tanks. it sits on a dolley with a battery set up and fuel line. I can tell you that the holley will prime itself from 20 feet way… Thats right. 20 ft… and it will do it through clogged fuel/ water seps. I drain entire tanks with them. It will prime. don't worry about it so much.
Cawley
03-07-2015, 12:40 PM #196000 RPM
- Calgary, Alberta
- 1,123
- 21
- 58
- 341
- 174
03-08-2015, 04:20 AM #20Markus' Performance Boating Links:
