Results 1 to 4 of 4
Thread: 235 hp v 6 x flow 1982
02-25-2015, 08:48 PM #1
All ,
Anyone have the diagram of the recirculating hoses on this engine?
Thanks
Bruss
02-27-2015, 03:10 AM #26000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
You will find the hose routing in the factory service manual for that year. I have attached a 1983 hose routing, but am not sure it's the same for your 1982.
02-28-2015, 12:13 AM #37000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
My scanner is down but the stock routing arrangement in the 1982 service manual shows the upper check valve connects to the middle port cover. Middle check valve to the bottom port cover. Lower check valve to the upper port cover. Same on both sides.
I recall my 1983 is not the same.
03-01-2015, 07:13 AM #4
Guys many thanks..
Bruss
