Results 1 to 7 of 7
    Mar 2014
    Kelowna
    STV Euro Ski Motor height and Setback Please Help
    I bought this 1996 Euro ski boat last summer, and never really got it set up right. I am new to these kind of boats and know little about setting them up. The boat is equipped with a Merc 2.5 260 20" 1.87:1 Sportmaster gear case, directly mounted on the transom third hole from the top (middle hole). I am running a 28P Mazco RE-4. The boat is located in the Okanagan BC, and mostly runs in a Lake. I have yet to run the boat WOT, the fastest I have run the boat is at 7000rpm 89mph. Could someone with a similar boat please tell me what height I should run the motor at, setback and what prop works best.
    Jul 2009
    West Coast, FL
    Try to get a 6 inch jack plate and 3 blade merc ET prop, maybe a 28 or 30 if you got the balls. The prop shaft should be about an 1 1/2 above pad. These are good places to start, you can fiddle around from there. Good luck, post some photos of your boat.
    May 2001
    Maine
    Correct... On my 2010 Euro with a 225 Sport XS the center of the Sportmaster lower unit is just about dead center with the center pod drain plug or about 1 3/8 to 1 1/2 above the bottom of the pad. I have a Bobs 5" manual jackplate... I wish I had Jack install a hydraulic plate when he built the boat. I am running a 32" Mercury ET and run 96 MPH at the 5900 - 6000 RPM. The motor has a 6k limiter. I am looking to try a cleaver and hope to get a few more MPH. Also have a 30" Mazco I picked up on S&F that I haven't tried yet.
    50 miles south of Augusta Ga.
    5 1/2 inches set back and 1 3/8 ths above was my sweet spot in mine.
    Mar 2014
    Kelowna
    Thank you for the information guys! I will try a 6" HydroDynamic Rapid Jack Plate, and start with the center of prop shaft at 1 3/8 above bottom of pad.
    Sounds like the Mercury Lightning ET prop is the most popular for STV owners. I would also consider a Mazco RE (round ear) prop, considerably cheaper than the ET prop.
    May 2001
    Maine
    Have you had a chance to try the boat?
    Mar 2014
    Kelowna
    I will have to wait until May, unfortunately I live in BC Canada and its still snowing here. I'll let you know in may how the new set up runs. I can't wait
