Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
    Nov 2012
    United States Oak Creek, Wi.
    Allison GS questions?
    Can an Allison Grand Sport, out accelerate an STV or HST Stream with say exact same motor, for comparison sake a 225 Pro Max. From Go to say 80 mph, since Tunnels not as fast out of hole but Allison less drag even when on top.
    Thanks, JIM
    Previous Boats:
    77' Switzer Craft 72 mph 175 hp
    86' Lazer LTV 80 mph 200 hp
    90' HST Bridgeport 97 mph 250 hp
    86' Valero YT 80+ mph 200 hp
    79' Vector 80+ mph 200 hp 85' Valero V 83+ mph/ Current 200
    88 Valero YT not so fast, no good motor
    NOW 85' Valero Vee 2.4 Bridgeport Carbs
    St. Cloud, FL
    It all comes down to weight. Most STV's are a 100-200 pounds lighter than your typical GS, and it wouldn't be an even match. Get the weights within 50 lbs or less... different story.
    2006 Spectre 24' SCS
    2020 Mercury 300 ProXS
    2001 Allison XB2003
    2006 Mercury 250XS
    1988 22' Velocity (sold)
    1995 Allison Grand Sport (sold)
    1998 Mercury Stock 2.5-260 SS
    1990 Velocity 30' - 502's (sold)
    Go Daddy Go! Racing
    May 2007
    STL
    I have seen hydrostreams and HST are much closer in size to the Allison SS, the grandsport is much larger.....I think a SS would also have a much better chance keeping up or being faster as well. Not a racer so I cant comment on that. But apples to apples the SS is the boat to compare a hydrostream to.
    [IMG][/IMG]
    Nov 2012
    just wondering. how fast the Grand Sport is considered, i realize SS would be a better match, but i am impressed with Grand Sport and wondering how they can take a wake at 90 mph if less than a foot. ? while "aired out" or is it like my Hydrostreams, you DO NOT want to do that? i am considering a GS.
    Previous Boats:
    Feb 2007
    lily lake WI
    Hands down stv as between the hst and the grandsport if both boats had fast trim i would say grand sport a lot of hst were heavy layups or water logged unless it was the the drag canopies Version but they were very rare
    May 2007
    STL
    Quote Originally Posted by Valero2.5 View Post
    The gandspirt hull is very similar if not the same hull as my previous xb2003. Wakes and chop 1 foot or less are taken quite well when encountered head on or close to head on it are the ones from the side that can be difficult.
    Not sure if even 12 inch chop is recommended are full wot, but it is manageable into the 80s running into the waves... Parellel to the waves is again more difficult.and I liked to stay below 70 in these situations...in the case of large cruiser, barge and wake board boat waves I preferred to slow down into the 20s and run up the swell and then down to avoid the hull pounding or stuffing
    [IMG][/IMG]
    Feb 2007
    lily lake WI
    Unless your your very serious about drag racing the grand sport is a way better lake boat you can take up to 2' waves at 90 with no problem i have run 27 miles in the upper 80's to low 90's whipping the piss out of some supposed 100 mph offshore boats lol
    May 2007
    STL
    [QUOTE=Michael J Giesler;2727091]Unless your your very serious about drag racing the grand sport is a way better lake boat you can take up to 2' waves at 90 with no problem[/QUOTE
    Wow my balls are not big enough to find out how skipping along the peaks at those speeds feel. Generally I slow down noticeably once things reach over a foot not because the boat wont do it necessarily, but it gets hard to see the occasional rouge cruiser waves once it gets much rougher and I hate hitting those unexpectedly......Anything over 1 foot waves I generally down to the 55-65 range depending on the spacing of the waves and direction they are coming from just to be a safe driver.
    [IMG][/IMG]
    Feb 2007
    lily lake WI
    Yep a rouge can make you go oh crap but i have over 350+ hours driving mine i always tell people when they get a gs take baby steps bat turns happen in a millisecond
    May 2007
    STL
    Quote Originally Posted by Michael J Giesler View Post
    I'm on my second Allison, owner for approx. 5.5 years and would be lucky to have 100 hours I bet.
    [IMG][/IMG]
    Aug 2004
    Charleston, SC
    The GrandSport could probably outrun the STV if both boats weighed the same and were loaded down with 4 large individuals. When I owned my GS the one thing that really stood out is that it carries weight very well. IMO it actually drives better when loaded down. Not as quick but you don't lose much top end....it's a very efficient hull even among the various Allisons when it comes to moving weight.
    Other than that scenario, the STV is gonna be quicker and faster. Don't know anything about the HST's except that they look cool as hell.
  12. #12
    Nov 2012
    All very good information, just take wakes head on, and yes want it for a lake boat, love the fact it carries weight well and does not lose much top speed even loaded, my HST did not take well, that good with its tunnel design, and lastly what are bat turns? wind takes nose left or right? thanks guys.
    -Jim
    Previous Boats:
  13. #13
    Pennsylvania
    Bat turns are when the nose of the boat drops quickly for various reasons, and the boat spins VIOLENTLY, usually to the right. When the boat falls off the pad at high speeds, it drops, the boat bow steers and around you go. If you are fortunate, you may stay in the boat without hitting anything to hard causing injury. If you are less fortunate, you will be thrown out of the boat. If you are even less fortunate, you will be thrown out of the boat, hit the side of the boat on the way out, and the boat will wind up, upside down. The good news is, LOL, this will all happen so quickly, that you will have no time to think about which of the outcomes will be yours.
  14. #14
    Nov 2012
    one Word, wow. is this similar to what my Hydrostream Vector would do? so its about bow angle of attack, going south quick? wow! nobody says how that can happen in Allisons? are we talking above a certain speed only? are they safer say below 85 or 90 mph? JIM
    Previous Boats:
  15. #15
    Bristol, WI
    The GS is a much larger boat than a Vector, no not a real good comparison. The Allison has a hooked pad so it doesn't need to ride with as much angle on top end, but the hooked pad is also why if you chop the throttle you are more than likely to hook the boat.(bat turn)
    Larry Gempp Jr.
