Results 1 to 9 of 9
Thread: 2003 Mercury Pro 250XB
02-02-2015, 09:57 PM #1Registered User
- May 2006
- 26
This engine came off a 20ft Bass Boat and was never in salt water, always garaged. No corrosion anywhere. 20"shaft. Powerhead is professionally built .030 and everything in it is new, every bearing and cage, new rods, pistons, Boysen reeds, injectors were cleaned and flow tested with results document. Have proof of all new parts. I built this for myself to keep, but need economy and dont need to run 75mph to catch fish. New fuel pump, Quicksilver oil pump, drive rod and gear. New Oil tank, key switch and harness with alarm. Heads were not resurfaced. No damage to block at all. New Mercury lower unit with Bravo 1 22pitch four blade ss prop. Engine has 3.1 hours on it, so does lower. Never repainted, original decals. Also comes with new Mercury key switch and harness with alarm and new oil tank on engine and new remote tank. Will trade for Optimax with low hours, must be clean. $7900 239-634-5748 installed it on a 18'8ft Action Craft.
Last edited by gulfzilla; 04-02-2015 at 12:11 PM. Reason: images, price drop,price drop on 3-31-15
02-03-2015, 02:17 PM #25000 RPM
- Jul 2002
- South Florida
- 944
Where is it located, and who did the rebuild? Which lower unit?
78 Hydrostream Vandal - under restoration here: VANDAL RESTORATION THREAD
86 21' Eliminator Daytona
17' Badetta sandbar skiff
02-03-2015, 02:39 PM #3
250 went to optimax air handler and motorola controls in 2002 so are we sure its an 03
02-03-2015, 03:32 PM #4Registered User
- May 2006
- 26
Naples fl. Built by Cory Cooper, pro engine builder. Lower is aftermarket cost was $900. Parts alone for rebuild was $3800.
02-03-2015, 03:33 PM #5Registered User
- May 2006
- 26
Yes its a 2003 limited edition 6200 3.0 rpm motor. Serial number is 2003
02-04-2015, 10:00 AM #65000 RPM
- Jan 2009
- WEDOWEE AL
- 161
pm sent
02-09-2015, 01:40 PM #7
Then why is it the old nippondenso electronics. I have the same xb motor in an 02 in the shop and it's the opti air handler with Motorola electronics with a gen 2 block
02-09-2015, 02:31 PM #8Registered User
- May 2006
- 26
02-09-2015, 03:39 PM #9
2003 is the last year of the 250XB as far as I know.
2004 Checkmate Pulsare Bowrider
2008 Mercury 300XS
91.7 - MPH
88' Hydrostream Viper
86' Carbed Bridgeport
102 - MPH
