Results 1 to 13 of 13
Thread: Opinons on rec90
01-28-2015, 05:38 PM #1Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Opinons on rec90
I recently last July moved and the boat did not get used alot I added fresh rec90 and sea foam and today I looked at the gas and it looked real cloudy and really rough. Is it just too long since burned and should I continue to use rec90 I drained the old and am ready to fill. I plan to use the boat at least once every 3 weeks it is a chevy 350 or should I use pump gas? All thoughts on this are appreciated all gas is never burned dry when I do use it. thanks Rick
01-28-2015, 06:13 PM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Only way I know of to be sure the gas is good, is to drain the tanks dry when done with the boat or car. Been working for me since the e-10 came around. Never bought any rec gas. And won't use any snake oil additives, they are expensive and don't always work.
01-28-2015, 08:19 PM #3Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
The only snake oil I subscribe to is sea foam but it is impossible for me to burn all the fuel what I might do is pump it out after each run and put in truck. 3.99 a gallon for rec fuel and 2.39 for E10. Thank you for your opinion.
01-29-2015, 07:06 AM #4Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Who runs this rec90? Does anybody see a big difference?
01-29-2015, 09:16 AM #5
I sell Rec 90 at the pump at my bar. I use it in my 225 promax and have never had any problems. It is a little pricey but contains no alcohol to eat away at your fuel lines and o rings. I sell a bunch of it mostly to pontoons and PWC's but no one has ever said they had any issues with it either.
01-29-2015, 04:44 PM #6
2.5 245 145psi 50%rec50%100LL AV. No problems for me yet!---It has not spoiled over the winters.
01-29-2015, 05:43 PM #7
rec 90 @145 psi and 8000 rpm for 4 years, no issues.
01-29-2015, 05:49 PM #8
01-29-2015, 06:40 PM #9Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
I appreciate the feedback what do you all think shelf life is of rec90? Mine had gone bad but there was a long time maybe 3 months and it just didn't look right. I might add there was no jelly or sediment but like glaze and very cloudy.
01-29-2015, 07:19 PM #10
If it was blended (mixed) it could have something to do with it looking cloudy.
01-30-2015, 07:50 AM #11
One other thing,rec is not a fast mover, so a load of it could be old by the time you bought it.If possable buy from a high volume seller.
01-30-2015, 08:17 AM #12Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Sea foam has alcohol in it. That may be what made it cloudy.
01-30-2015, 08:25 AM #13
My bar is on the lake and we are pretty seasonal. We do get the occasional sled needing gas in the winter but it normally sets all winter(4 months) and I have seen no color difference.
