Results 1 to 11 of 11
    Dec 2012
    tn
    Got last seasons salt off PH- what to protect it with now? 2.5 lt merc
    Got all last season salt off under the cowls. Some of the salt crystals were big enough to put on pretzels- I have Corrosion X HD- that is like spraying it down with nice smelling gear lube.
    Anything else worth trying? Merc 2.5lt Salt water fishing motor.
    Spring WILL come.
    Moline,Ill
    http://www.fluid-film.com/ I use it on my snow plow and salter
    is gone
    CRC 6-56 is used in the industry up in the north east. No build up and clear.
    CRC is what I have used for years with great results, still do. Just need to be careful to not over load or spray where it will sit or built up around rubber, it will soften it up after some time.
    still lurking I see
    Jul 2009
    savannah,ga.
    Used CRC 666 (they since changed it to 656) in the Keys and never had corrosion. Now I use the 656. It's way cheaper to get gallons and use a spray bottle. After a while the ph had such a coating I didn't spray as often, just wash down. Everything external got it every time. Never had any corrosion.
    Jun 2002
    Winter Haven Fl.
    Quote Originally Posted by BUZZIN' DOZEN View Post
    Best stuff I ever used, it is a little messy but it is designed to use on tractors that stay out in the elements all their life, also no petroleum distillates so it does not break down rubber. Matt
    still lurking I see
    Exactly, be careful....
    BUZZIN, that stuff looks very interesting and good. I think I need to try some.....
    Dec 2012
    tn
    Ok fluid film on PH- and overspray on mid-section that I planned to give a fresh coat of paint- How do I get this stuff off so I can paint?
    Jul 2009
    savannah,ga.
    3M wax and grease remover
    Does a good job on electrical connections to.
