Results 1 to 15 of 19
Thread: 2004 STV Euro Ski with 280
01-20-2015, 12:34 PM #1
SOLD - Thanks S&F!
Performance – It does exactly what a Euro with a 280 is supposed to do. Last time out with me, wife, ½ tank fuel and all our stuff went 114 gps mph at 8,500 rpm on limiter with 30ET (12% slip). Boat averages 4.2 mpg no matter how it is run.
Boat – 2004 STV Euro Ski – Built at Triad Powerboats/Wally Lamkin, Kevlar double lay-up option, Console, Carpeting Delete, In-Control shifter, foot throttle and feet rest (3), Detweiler 6" manual jack plate, Sea Star Pro 2.0 Hydraulic Helm Kevlar hoses O/B cylinder, Custom full cover including engine, Sump Pumps (3), amber courtesy lights (6), JBL MR-18S AM/FM/CD waterproof face stereo with MP3 aux plug JBL MA6004 4-channel amplifier 640 watts JBL MS9200 6" x 9" marine speakers (4) with boxes, Ski pylon 47” x 1-3/4” aluminum, R & R E Ladder mounted to jack plate, grad handles, keyed battery switch, pole holders, transom vents removed, Gauges – GPS 120 Speed w/recall, 10K Tack, EGT, Fuel PSI, Stainless Trim Indicator, Water PSI, Water Temp, Volts, Fuel Level, Depth Sounder
Engine – 2005 Mercury 2.5L 280 Offshore, (original consumer ECU but rev limiter has been raised to 8,500 rpm), 30 hours since JSRE rebuild in 2010, 126 hours total, currently 136 psi compression and 4% leak down averages across board (with my gauges), full DDT readouts compression and leak down history available to legitimate buyers, JSRE rebuild at 96 hours included – Air Horn & Reed Plate (20 & 35 degrees) Angle Cut, Case Front Half Machining 0.050", Block Modifications Rod Pockets & Exhaust Ports, Straighten 3 Bores and Hone, Wizard Pistons & Rings Kit RaceKote Thermal Barrier, Wizard Light Piston Capped Top Pins, Wizard Plug Wires Reactive Core, Bearings, Brucato Injector Calibration, TDR Reed Valves, Oil Check Valves (top & bottom), Intake 1” spacer kit, after break in always run on 93 pump gas and Pennzoil Marine 100% Synthetic oil, Sport Master – replaced the prop shaft seals last year, replaced shift shaft bushing assembly with a Mercury/Reynolds Modified couple years ago.
Props (both purchased new and low hours) - Mercury Lightning ET, Lab, 14-1/2" x 30 (5 hours) and Mazco RE 4 - 14-1/4 x 32 (10 hours)
Trailer – 2004 Loadmaster Aluminum, Aluminum Silver Star Wheels, Swing tongue hinge
Extras –
Mercury DDT with V5.0 OB software cartridge and manual and adapter harness and hard case,
Mercury 2.5 EFI/SS/OS Operation/Maintenance Manual, Service Manual and Parts Manual,
Various extra parts (some new) and tools (some new never used) for this boat, engine and trailer collected over the years…..cleaning out the garage.
Condition – I would rate it an 8 out of 10. Everything on it works as it should. Anything broken was replaced. The boat is completely reliable. I have replaced all hoses and most wires since new. It has a few normal wear scratches.
Full Disclosure - Bottom hull has a few scratches on forward sections (1st owner 1st outing low tide parking issue) which does not affect performance in any way, also cover has some wear.
Reason for selling – Wife wants a fishing boat and I don’t want to support two boats. (This is my 4th over 100 mph boat in the last 12 years.)
Boat Location – Muscle Shoals, AL
Price - $27,500 for total package including boat, engine, trailer, props (2), all my extras including DDT.
Contact – Walter Goetzmann (256) 275-2 six two two or wagoetzmann@tva.gov
I’m the 2nd owner. 1st owner (Scott Marquardt) special ordered and purchased from Diamond Marine in 2004 then added the 280 a year later. I purchased from Scott in 2008. I have all original paperwork, full documentation including excel spreadsheet of every item since new which I can send to legitimate buyers. I have documented over $47K in boat.Last edited by wagoetzmann; 02-11-2015 at 07:35 AM. Reason: Boat Sold - Thnaks S&F!
Walter Goetzmann
2018 Talon XL 22 / 400R
01-20-2015, 01:22 PM #2
If it had a tandem axle trailer I would be all over this.
nice pkg.
01-20-2015, 01:35 PM #3Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
God, Country, and Fast Boats
01-20-2015, 04:42 PM #4
Sorry I have never been satisfied with a single axle. It has to look as good as it does on water as it does on the trailer. by the time I pay taxes and buy a tandem that's another $5k.
01-20-2015, 08:12 PM #5
01-20-2015, 10:52 PM #6
beautiful rig!
17 ACTION & 19 ACTION
1987 ACTION TVX 200 MERC ( BIG BARNEY MADE A FEW). SOLD
21 STALLION 200 PROMAX BOTTOM FELL OUT. SOLD
2004 21 EXTREME /2003 MERC PRO XB250 .SOLD
1996 STV EURO 260 TO 2004 15' 280 MERC .SOLD
1995 STV EURO 1997 260. SOLD
NEW 21 GREEN EXTREME. SOLD
1998 STV EURO USED TWICE SOLD!
1997 21 SKATER / 300XS SOLD
1987 21 SKATER /15 INCH 300 XS
01-21-2015, 06:50 AM #7
Great Boat, Walter took it to another level after me.... Whoever gets it wont be disappointed... Wish I could keep them all !
Variety of stuff
01-24-2015, 03:37 PM #8
2004 STV Euro Ski with 280 - Extras
Guys here are a few pictures of the extras which come with this package.
1. Mercury Lightening ET 30
2. Mazco RE4 32
3. Mercury DDT with V5.0 OB software cartridge and manual and adapter harness and hard case.
4. Various extra parts (many new) and tools (some new never used) for this boat, etc.
Sport Master – garden hose kit, prop shaft nut wrench, prop shaft seal seating tool, shift shaft seal seating tool, o-ring kits, water impeller, prop hub kit parts, etc.
Engine – lift ring tool, flywheel puller tool, fuel pressure regulator, plugs, fuel pump relays (2), water psi sender, exhaust baffles, etc.
Boat – ski tow bar, steering wheel hub, etc.
Trailer - boat guides, etc.
Various – whoever buys this boat will get the garage clean out deal, more parts than listed like new alcohol resistant fuel hoses, etc., ...... anything I can find that goes with this boat, engine or trailer ..….
5. All original paperwork which came with boat including anything ever done to it over the years, 3 ring binder with years of STV History articles, Mercury High Performance Boat Operation Guide, Mercury 2.5 EFI/SS/OS Operation/Maintenance Manual, Service Manual and Parts Manual, 2005 Mercury Racing Engine Brochures, etc.Walter Goetzmann
01-24-2015, 03:51 PM #9
Beautiful boat. Tandem axle trlr would NOT keep me from buying it. ...If it doesn't sell for a while I may be making a trip south.....
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
01-24-2015, 11:56 PM #10
john4utvols has exceeded their stored private messages quota and cannot accept further messages until they clear some space......
As far as duel axles, why not just add an axle, fenders, wheels to the existing trailer?Walter Goetzmann
01-25-2015, 01:58 PM #11
01-25-2015, 07:22 PM #12
who's boat is this ? your EURO is sweet and If I just didn't get one I would be all over this even if was on blocks . lol , I prefer single myself!
01-30-2015, 09:21 AM #13
TTT. I took a bunch of new pictures last weekend which I could send.
Walter Goetzmann
01-31-2015, 05:44 AM #145000 RPM
- Sep 2013
- sarasota, florida
- 748
- 12
- 12
- 48
nice
01-31-2015, 06:37 AM #15
I drove this boat once when Scott had it , nice ride !
