Results 76 to 90 of 129
Thread: Piston and rod balancing
01-22-2015, 07:35 PM #76
And why do think that is ... ?
Its a big jump to comprehend a v6 at 60 or 90degree to then have none less the ones on the end?
I wonder what a flat 6 2 stroke crank would look like?
01-22-2015, 08:02 PM #77Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
01-22-2015, 08:28 PM #78
As far as the V6 vs I3 thing goes look at the old Merc Race motors that were V6's with only one bank loaded.
01-22-2015, 08:41 PM #79Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
sst90, I guess it had a std v6 crank?
01-23-2015, 09:30 AM #80
Lets see what this stirs up. Remember watching the whole tractor move back and forth a but just idling.
01-23-2015, 09:43 AM #81Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Looks like a hit or miss engine. Super slow rpm with that huge flywheel to keep things moving. Always fun to watch them run. Can get to see them at antique tractor shows.
01-23-2015, 07:35 PM #82
I doubt you'd find a Konig 6 apart to show the crank. Konig's used single crankcases for the opposing pairs, the paired cylinders fire together; the Porsche crank would look the same even though the cylinders fired alternately.
Corvair crank
Konig used pressed together segmented cranks, so it wouldn't look like this, but would have the same bearing & throw layout
01-23-2015, 07:43 PM #83Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
So the Konig didnt have counterweights on each cylinder then as above
01-23-2015, 10:14 PM #847000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Just to be helpful, V6 engines of 60 or 90 degree bank angles don't balance worth a crap without external balance shafts. Look at any auto V6. They don't spend that money unless they have to. So an outboard is going to shake, just a matter of how bad at what RPM.
Some folks that know a lot more than I say that most outboards are balanced to produce the least noise, vibration and harshness at idle. Has little to do with how it runs at WFO. And at idle, the different suction/pressure forces on top and under the pistons are significant compared to an four stroke auto V6. So traditional thinking may not explain the factory counterweighting.
The flat 6 has the pistons moving opposite so the reciprocating forces almost cancel and a very good balance should result. The forces don't perfectly offset because the crank journals and cylinder bores are offset by the space needed for the crank journals, bearings and webs.
01-24-2015, 12:56 AM #85Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
2 cyl etec skidoo has a balance shaft these days
01-24-2015, 01:05 AM #86Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
So heavy to light rods in omc looper, can you tell the difference?
where do I grind the crank to get back to 50,1,or 2%Last edited by powerabout; 01-24-2015 at 07:28 AM.
01-25-2015, 08:59 AM #87
While it's true that 60 and 90 degree 6's do better with the addition of a balance shaft. It is far from needed. The automakers go way out of their way to make cars feel like your not riding in a car. When gas prices were working their way to $5.00 a gallon , the auto industry went with smaller more efficient powerplants. Hence the extra shaft.
I can tell you from experience , an outboard motor is smoother from idle on up after it is balanced. And as stated before , go watch them do a crank balance job from start to finish, and you will see for yourself.
On race car motors , I like to use a vacuum pump that is regulated to -15 lbs. So there are crankcase forces at work on both 2 and 4 cycle engines ...
01-25-2015, 12:22 PM #887000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
No argument from me that custom work can make an outboard run smoother. Same as it has always been for any mass produced engine. But there is no solution to make a V6 have perfect or even very good balance. You can just make them suck less than the factory job. If it is worth the time and expense is up to the individual.
01-25-2015, 01:40 PM #89Markus' Performance Boating Links:
01-25-2015, 01:40 PM #90Markus' Performance Boating Links:
