Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 105
  1. #31
    Sitka, Alaska
    This is the best picture I can find of the rail I'm using. This is on Aaron Wacholz "Stealth" Virage he made. I was fortunate enough to be rolling into Arrons shop as he was taking his boat out for it's maiden voyage. I got to ride shotgun for the second lap then drive it on the third lap. I got the idea to glass everything together from his boat. It sure ties everything together.
    Ron Pratt
    '91 Virage "The LAST Virage" 15" 280
    26' Grady White "fish getter"
  2. #32
    Jun 2009
    Bristol, Connecticut
    Where did you guys get the rail? It looks nice
  3. #33
    Jun 2009
    I might need something wider like the stock one because my gel coat is kinda faded in some parts.
  4. #34
    Sitka, Alaska
    This one is the same size. Just the materials are reversed. I don't remember the cost though.
    Ron Pratt
  5. #35
    Jun 2009
    I found a site with various rub rails, I think I found a style that will work. It comes with both the track and the rubber.
    I just took the top deck off the boat today. I will start taking the floor out this week.
  6. #36
    Jun 2009
    Barbour plastics has lots of rail profiles, they are on the web.
    Jun 2009
    That's good stuff. Whaler uses it on their small boats. Heat it up before install....
    Jun 2009
    Cut part of the floor up and took some SOGGY foam out of the sponsons. Actually had water pooled in the bottom of the right sponson. Towards the front seems more dry but there was no drainage what so ever in the sponsons.
  11. #41
    Jun 2009
    The soggy foam was easy to take out and was able to pry it out in larger sections, some about 2 feet long. These pictures are a little old, I have all but the very bow ripped up now.
    I have to support the sponsons on the trailer a little bit. They flex pretty bad when I bounce in the boat. I have decided on bulkheads in the sponsons to tie the outside of the sponsons to the inside
  12. #42
    Dec 2011
    Ottawa
    Your doing a great job aaron, heres a shot of my buddy's freshly restored Virage, with my cdn.edition AE-21 blocking the full view
  13. #43
    Jun 2009
    Cool- looks like you guys are having fun up there!
  14. #44
    Jun 2009
    I was looking at the boat and thinking I might cut out the sides of the ski locker completely and replace them with stringers. It will look similar but w ill be something more solid to mount the gas tank and transom knees to.
  15. #45
    Jun 2009
    Just went to the dump, took 260 lbs out of the boat excluding water that evaporated, was mainly the flotation and floor
    I have a little bit more floor to take out and I will be cutting the transom next
