Page 3 of 41 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 31 to 45 of 603
  1. #31
    I guess she was pretty rotten..
  2. #32
    Buddy they all look that way..Ive not seen one that's dry and new yet..Lol.
  3. #33
    Quote Originally Posted by WIPolaris View Post
    Here are two quick pictures of my Jig. Nothing too complex. Found a long pallet to use as the base to build off of. After I got the boat settled on it I used the spray foam and put a layer between the jig and the pad (with wax paper barrier. I thought that would help to fill any voids and keep the pad as close as possible to original. I think it turned out good, definitely not as complicated as many guys jigs, but I think it worked. Boat runs straight now.
    Let me know during the whole build Mark if you need any pics. I don't get on here much anymore, but you know how to find me.
    Thanks
    Thanks Dave! I always thought that was a really nice Jig. I know you did it right because that boat is amazing to drive
  4. #34
    Mark a friend and I cut the floor out of my 1971 Sidewinder I/O today . Thank goodness the main stringer running down the center was still good . time to pass her on to another owner , I've owned it since 1973 , have not run it since 2006 . It's time .
  5. #35
    Quote Originally Posted by Tom Foley View Post
    Got any pics of it? I don't recall seeing it in your shop.
  6. #36
    Aug 2012
    beaumont, tx
    Hope every one had great holidays!
    Lil boat looking good. ..keep bringing em back. I've always loved the pics of scotty's (think that's right? ?) vandal...he's always got that thing aired out.
    Picked this up this week. ....shortest prop I've ever ran. Should be a blast with the 2:1 gears in 660ft!
  7. #37
    Quote Originally Posted by FlowMaxx View Post
    Yes here are a few .
  8. #38
    Cool!! Looks like it is in nice shape
  9. #39
    Nov 2003
    This is the jig I built to rework my Viper. It may be a little extensive, but since I split the hull I didn't want to take any chances distorting the bottom. I made a cardboard template of the bottom and built the jig accordingly. I only had about 100 bucks in lumber to build it and screwed it all together. The coolest part about it was, when I was finished with it, I just unscrewed it apart and a fellow screamer came over to pick it up in his SUV and gave me 100 bucks for it. He is restoring a Bicentennial Viper with it... I have more detailed pictures if you interested. As Jeff mentioned, I would be more than willing to help wherever I can.
    Quote Originally Posted by Sonik View Post
    Larry,
    Joe / Proprider built one for his Viper resto a few years ago. I'm pretty sure this is the one you are referring to. It obviously wouldn't fit a Vking due to the strake and pad differences but do a search here.....it might give you some ideas. Jos is a good guy and would be more than willing to chat with you about what he did. I'm sure he'll swing through here at some point. Look forward to your progress!
  10. #40
    Quote Originally Posted by proprider View Post
    I remember seeing that one. That sure is nice. Thanks for sharing
  11. #41
    That's the jig I was thinking about also..It was one of the best built jigs ive seen.@ Nice work..
  12. #42
    Jun 2009
    Bristol, Connecticut
    Just picked up a 1990 Hydrostream Virage. Will be continuing work on it in the Spring. Plan to take out the floor and inspect the core and sponsons for wetness. Any online help would be appreciated
  13. #43
    fl
    I think that might hav been the jig I was thinkn of .... Thanks alot I was thinkn of flipping the boat then clamping a sheet of plywood to the transom and drawing out the bottom shape and laying the boards out on the bottom and attaching them to the transom board then supporting the bow like u hav .... Thanks alot I think I hav some good ideas now and will b paying close attention to this build ....
  14. #44
    I will see if I can get Scott to share some of his Virage pics on here. Full resto on it and he has spent a ton of time and $$$$ on it. Thanks for sharing
  15. #45
    Larry, we would love to see your progress on here as well
