Results 1 to 15 of 25
Thread: STV rebuild
    Pekin, IL
    STV rebuild
    Well I said I was not gonna do this ever again but you all know how things go. So a friend has this STV that was being used as a roundy round boat before he acquired it. This thing is ultra light. Had aluminum plates bolted to the sponsons to help turning. My friend was a beginner so he bought the wrong boat but tried to make the best of things. Hung a 2.5 200 on it and had a ball right up until he hooked it and threw himself thru the side of the boat. Decided not to let that happen again and went out and bought a capsule from Seebold and bolted and glassed it in place. Not what I would consider a good idea but it worked for him. We did some trading and I ended up with this little jewel. Split the hull in order to remove the capsule and found several disturbing things. Some of the stringers feel hollow and that can't be a good thing so they will be replaced. Also have to remove a pad that was added to the bottom for more lift (I assume. Either way it is coming off). Will rebuild the dash area and give er a coat of paint. Still have not decided how to build it, race or pleasure, but am leaning toward race due to it's weight. I am not a glass man so I will certainly have many questions about what, how, why, and when. I will read first and ask second. Bring on the itch.
    Rock
    Team Junk
    Pekin, IL
    The aftermath
    Team Junk
    Sep 2008
    Treasure Island Fl
    Subscribed….. I love projects like this. Happy to help, if I can
    Cawley
    Pekin, IL
    Hey Cawley. You finished one of my projects, what do ya think about an STV? Just kiddin man. Hope you're doin well.
    Rock
    Team Junk
    Jul 2008
    Shreveport, LA
    What year is it? Looks like a narrow deck ProComp.
    Hollow stringers....yeah I know about that. I replaced all of them in mine as well as the knees and transom......good project. Pete
    http://www.screamandfly.com/showthre...interior-re-do
    1986 Skeeter Starfire 150
    2000 Ranger R81VS
    1995 Liberator
    1988 Searay Sorrento
    1986 STV Pro Comp 280 "Area 51"
    1990 STV Pro Comp
    Aug 2012
    beaumont, tx
    SUBSCRIBED .........i would like to build one of these one day.
    Aug 2014
    Rowley, MA
    Hey, could someone explain the term "Hooked" used by the OP
    is there a video somewhere that shows a boat hooking
    BTW nice build
    Pekin, IL
    Welcome to the site. Hooked = unexpected 90 degree turn. Most performance hulls can turn really sharp. When that happens and the driver is not expecting it, he often goes a different direction than the boat.
    Rock
    Team Junk
    Jun 2001
    Kentucky
    stv
    here is a pic i had wondering if the same boat
    Sep 2004
    Illinois
    Hey Randy..looks like fun. If you need some muscle, gimme a call...thats the least i could do for ya after all the favors! Wife and I owe you a trip out your way....its been too long. Around for the holidays?
    1976 Hydrostream Viper - 2.5 EFI
    Resto Thread Here
    2010 Go-Pro Stuff
    "The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
    Pekin, IL
    BRB....I do believe it to be the same hull. Not a color you see every day. So this was your boat?
    Jeff....We are in town this year. Going to New York to see the grandkids first of February. Hope you and midge have a great Christmas and we will get together soon.
    Rock
    Team Junk
  12. #12
    Jun 2001
    Kentucky
    No....but i heard it was fairly light.....instigator knew about it i think
  13. #13
    chesterfield va
    brb is that boat red and gray and is it side by side seating
  14. #14
    Pekin, IL
    Boat was originally red as seen when I split hull. Don't know about the gray. Tried to weigh it using a formula I found online and it is a bit heavier than I thought (if the formula is accurate). With back seat out it came in at around 530#.
    Rock
    Team Junk
  15. #15
    chesterfield va
ID:	311934was wondering if this was the boat
