Results 1 to 15 of 25
Thread: STV rebuild
12-22-2014, 04:27 PM #1
STV rebuild
Well I said I was not gonna do this ever again but you all know how things go. So a friend has this STV that was being used as a roundy round boat before he acquired it. This thing is ultra light. Had aluminum plates bolted to the sponsons to help turning. My friend was a beginner so he bought the wrong boat but tried to make the best of things. Hung a 2.5 200 on it and had a ball right up until he hooked it and threw himself thru the side of the boat. Decided not to let that happen again and went out and bought a capsule from Seebold and bolted and glassed it in place. Not what I would consider a good idea but it worked for him. We did some trading and I ended up with this little jewel. Split the hull in order to remove the capsule and found several disturbing things. Some of the stringers feel hollow and that can't be a good thing so they will be replaced. Also have to remove a pad that was added to the bottom for more lift (I assume. Either way it is coming off). Will rebuild the dash area and give er a coat of paint. Still have not decided how to build it, race or pleasure, but am leaning toward race due to it's weight. I am not a glass man so I will certainly have many questions about what, how, why, and when. I will read first and ask second. Bring on the itch.
RockTeam Junk
12-22-2014, 04:31 PM #2
The aftermath
Team Junk
12-22-2014, 06:33 PM #3
Subscribed….. I love projects like this. Happy to help, if I can
Cawley
12-22-2014, 07:15 PM #4
Hey Cawley. You finished one of my projects, what do ya think about an STV? Just kiddin man. Hope you're doin well.
RockTeam Junk
12-22-2014, 08:16 PM #5
What year is it? Looks like a narrow deck ProComp.
Hollow stringers....yeah I know about that. I replaced all of them in mine as well as the knees and transom......good project. Petehttp://www.screamandfly.com/showthre...interior-re-do
1986 Skeeter Starfire 150
2000 Ranger R81VS
1995 Liberator
1988 Searay Sorrento
1986 STV Pro Comp 280 "Area 51"
1990 STV Pro Comp
12-22-2014, 08:17 PM #6
SUBSCRIBED .........i would like to build one of these one day.
12-22-2014, 11:25 PM #7New Member
- Aug 2014
- Rowley, MA
Hey, could someone explain the term "Hooked" used by the OP
is there a video somewhere that shows a boat hooking
BTW nice build
12-23-2014, 08:16 AM #8
Welcome to the site. Hooked = unexpected 90 degree turn. Most performance hulls can turn really sharp. When that happens and the driver is not expecting it, he often goes a different direction than the boat.
RockTeam Junk
12-23-2014, 07:19 PM #9
stv
here is a pic i had wondering if the same boat
12-23-2014, 07:43 PM #10
Hey Randy..looks like fun. If you need some muscle, gimme a call...thats the least i could do for ya after all the favors! Wife and I owe you a trip out your way....its been too long. Around for the holidays?
1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
12-24-2014, 08:53 AM #11
BRB....I do believe it to be the same hull. Not a color you see every day. So this was your boat?
Jeff....We are in town this year. Going to New York to see the grandkids first of February. Hope you and midge have a great Christmas and we will get together soon.
RockTeam Junk
12-24-2014, 10:18 AM #12
No....but i heard it was fairly light.....instigator knew about it i think
12-24-2014, 12:15 PM #13
brb is that boat red and gray and is it side by side seating
12-24-2014, 12:22 PM #14
Boat was originally red as seen when I split hull. Don't know about the gray. Tried to weigh it using a formula I found online and it is a bit heavier than I thought (if the formula is accurate). With back seat out it came in at around 530#.
RockTeam Junk
12-24-2014, 12:58 PM #15
