Results 1 to 10 of 10
Thread: Engine weight question
12-22-2014, 02:12 PM #1
I am trying to make a comparison in weight between a V4 Johnson 90 to a V- 6 Mercury 2 liter 150 . Both 3 ram trim engines .Pontoon re- power . Thanks in advance for any responses . Merry Christmas !
12-22-2014, 02:34 PM #26000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
You did not state a year. The 90 Johnson's came in two flavors, the older crossflow and the newer loopers. The 90 degree crossflow weights in at around 301 and the 60 degree looper is around 319.
12-22-2014, 02:42 PM #3Team Member
- Lake Coochiching, Ontario
- 7,705
- 269
- 472
- 1541
- 6 Post(s)
There were 90 degree and 60 degree looper V4s and the cross flow. My 115 HO is a 60 looper and the heaviest at 375. A 90 carb looper would be between mine and the cross flow.
12-22-2014, 03:26 PM #4
Thanks guys it's a 1999 60 deg Looper . VS a 1988 - 150 2.0 Merc.
12-22-2014, 03:55 PM #5
belive the 4 will do better on fuel
most overnite successes usually take at least 10 years
Certified turd polisher,
12-22-2014, 07:57 PM #62008 Mirage V-Racer 1983 2.0L Mercury 15"
2010 Mirage V-Racer 1987 2.4 Original SST140 Powerhead
1974 Hydrostream Viper
1977 Hydrostream Viking
1995 Mirage River Racer " Boat On Loan" Thanks Mike Mullins 2.5 245hp 15"
12-22-2014, 08:28 PM #7
i vote for the 2.0. if my 3 cyl jonrude ever takes a crap, i'll be looking for an old v 6 for my pontoon.perfect combo!
LTB OLDGUY
12-22-2014, 08:55 PM #8
If I remember right, the Merc will be about 60 pounds heavier. Took a CF V4 off my 16 Baja and put a 2.5 Merc on it, not very noticeable difference in the squat
12-23-2014, 10:06 AM #9Team Member
- 7,705
- 269
- 472
- 1541
- 6 Post(s)
claimed weights
1988 2.0 150 378 lb
1999 60 deg V4 319 lb
12-23-2014, 10:45 AM #10
That I can deal with . There is a large open area in the motor well void , I will fab up an air tank so to speak to go in that void to add flotation at rest . Thanks guys , Merry Christmas !
