Results 16 to 30 of 66
Thread: V4
12-20-2014, 07:21 AM #16Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
12-20-2014, 08:10 AM #17Member
- Feb 2010
- Minocqua
- 97
12-20-2014, 09:29 AM #18Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
What we need is an adapter and new bubble back cover to put it on a v8 mid so one 90 degree turn then straight down to the megaphone...
There's a winter project
12-20-2014, 05:10 PM #19'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
12-20-2014, 05:13 PM #20'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
12-20-2014, 05:29 PM #21
Okay now we wait.
Set a work light against the head to keep it warm overnight. Figgered it'd help the goo cure? Says to give it 24 hours regardless.
We'll see what happens tomorrow. Keep yer fingers crossed ...'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
12-20-2014, 06:26 PM #22"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
12-20-2014, 07:15 PM #23
12-21-2014, 09:39 AM #24
When I ran a Kawasaki KZ powered drag big with big compression we always had a problem with the heads leaking at the snouts in front and back of the timing chain. We used big ARP studs and copper head gaskets and the head would warp when torques down enough it would leak there.
We finally solved the leak using Toyota Seal Packing. Its a black sealer Toyota used on their oil pans and the stuff was amazing. Im thinking it might work for you.
http://www.ebay.com/sch/sis.html?_nk...d=31053112312213' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
12-21-2014, 09:43 AM #25
The other option would be a dab of 3M 5200. It will take some heat and is rated to 190 degrees which is usually a conservative rating from the manufacturer. If it leaks after your fix I would try a little.
21' Paramount
Mercury 300 Promax
12-21-2014, 10:27 AM #26
12-21-2014, 04:18 PM #275000 RPM
- Aug 2002
- florida
- 804
- 13
So did you see any improvement from the cut out in the exhaust!!
12-21-2014, 07:16 PM #28Member
- Feb 2010
- Minocqua
- 97
Yes , 3 - 400 Rpm, and it seemed to be quicker upon acceleration (if one can really tell).
12-21-2014, 07:23 PM #29
Ha! Nah, still too early to tell ... Though we did get her runnin, with no water leaks. WooHoo!
She sure want's to run but seems like #1 & 3 aren't firing just right. Checks out fine with spark tester but if'n ya pull the leads when it's runnin it don't make much difference?
Thinkin I might swap back to dual powerpacks'n see if that makes a difference. I dunno what else to do. Purty sure we got the correct flywheel, stator & timer base for this CD4 setup?
Short vid here: http://youtu.be/cnBQhNazEY8'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
12-21-2014, 07:34 PM #305000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 336
- 134
- 7 Post(s)
Ya, sure sounds like she is missing, what happens when you bring up the RPMs?
Thinking maybe weak spark.
