Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 66
Thread: V4
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by wired247 View Post
    JB Weld doesnt belong in the same book as marine tex. Marine Tex is a hands down superior product.
    Truer words have never been spoken.JB might be useful for some things,but around me I'm not sure what,it won't take heat or exposure to fuel...might seal a bathtub leak for a while,Chris
  2. #17
    Feb 2010
    Minocqua
    Or you can cut the cooling line out, weld the block and reroute the cooling line like I did.....Click image for larger version.
ID:	311642Click image for larger version.
  3. #18
    8 Post(s)
    What we need is an adapter and new bubble back cover to put it on a v8 mid so one 90 degree turn then straight down to the megaphone...
    There's a winter project
  4. #19
    Jan 2010
    Venice, FL
    Quote Originally Posted by Chris Carson's Marine View Post
    Got it. No JB Weld.
  5. #20
    Jan 2010
    Venice, FL
    Quote Originally Posted by 194268 View Post
    That's purty killer.
  6. #21
    Jan 2010
    Venice, FL
    Okay now we wait.
    Set a work light against the head to keep it warm overnight. Figgered it'd help the goo cure? Says to give it 24 hours regardless.
    We'll see what happens tomorrow. Keep yer fingers crossed ...
  7. #22
    Quote Originally Posted by 71V153 View Post
    Okay now we wait.
    Hey Is that one of those new fangled "towel head" OBs !! Best of luck. Ha Robby beat ya to it. Gary
  8. #23
    Jan 2010
    Venice, FL
    That'd make sense. Splain why it's been a thorn in my ass since the get go ...
    Just checked and the craport smells like 'Snuggle'? If'n that don't make the motor behave I dunno know what will ...
  9. #24
    Aug 2004
    Venice, Florida
    When I ran a Kawasaki KZ powered drag big with big compression we always had a problem with the heads leaking at the snouts in front and back of the timing chain. We used big ARP studs and copper head gaskets and the head would warp when torques down enough it would leak there.
    We finally solved the leak using Toyota Seal Packing. Its a black sealer Toyota used on their oil pans and the stuff was amazing. Im thinking it might work for you.
    http://www.ebay.com/sch/sis.html?_nk...d=310531123122
    21' Paramount
    Mercury 300 Promax
  10. #25
    Aug 2004
    Venice, Florida
    The other option would be a dab of 3M 5200. It will take some heat and is rated to 190 degrees which is usually a conservative rating from the manufacturer. If it leaks after your fix I would try a little.
    21' Paramount
    Mercury 300 Promax
  11. #26
    JB will do the job. The head/gasket is doing most of the work JB will just take up a few thou to keep water where it belongs..
  12. #27
    Aug 2002
    florida
    So did you see any improvement from the cut out in the exhaust!!
  13. #28
    Feb 2010
    Minocqua
    Yes , 3 - 400 Rpm, and it seemed to be quicker upon acceleration (if one can really tell).
  14. #29
    Jan 2010
    Venice, FL
    Quote Originally Posted by ultrafast View Post
    Ha! Nah, still too early to tell ... Though we did get her runnin, with no water leaks. WooHoo!
    She sure want's to run but seems like #1 & 3 aren't firing just right. Checks out fine with spark tester but if'n ya pull the leads when it's runnin it don't make much difference?
    Thinkin I might swap back to dual powerpacks'n see if that makes a difference. I dunno what else to do. Purty sure we got the correct flywheel, stator & timer base for this CD4 setup?
    Short vid here: http://youtu.be/cnBQhNazEY8
  15. #30
    7 Post(s)
    Ya, sure sounds like she is missing, what happens when you bring up the RPMs?
    Thinking maybe weak spark.
