Results 1 to 10 of 10
    Northern Minnesota
    94 mercury 135 black max
    What can I do to get more power out off my 135
    Dec 2011
    Sunny Oregon
    How much money do you have?
    Sep 2002
    Dunlap,TN.
    If the engine is still running.....For starters you can gain 15HP by changing the carbs as the 135 and 150 are the same engine. Then you can start with the basics.....Cutting the heads to raise the compression and increasing the timing slightly (after removing all the "black" boxes) on a healthy engine. There are many things that can be done to a 2L internally to spruce it up (especially the fat block 2L) but then it becomes a issue of the cost of the mods versus stepping up to cubic inches (2.5) as sometimes it is more cost effective and then Wired247 question becomes a very good one. Just my .02
    James Perry
    Northern Minnesota
    How much can I shave off my heads and still run 91 octane
    Dec 2011
    Sunny Oregon
    Tightest you'll want to run is about 28 cc's chamber size. Idle relief slot motors cant really be tested for cranking compression like non slot motors and give you meaningful numbers . 28CC works fine on 91.
    Aug 2010
    Barrie, Ontario, Canada
    Quote Originally Posted by Jola454 View Post
    Not sure how much money you were looking to spend for the improvements. We had the same scenario back in '07 or '08 and figured rather than spend the money to "get more out of the 135" we sold the 135 and went for a used 2005 175 Opti ( 2 years old at the time) and picked up 10 mph and way better fuel mileage and all around performance. The 175 was only about 35 pounds heavier than the 135 so it was negligible. Good luck with your decision.
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
    Sep 2002
    Dunlap,TN.
    I always cut the heads to the same cc as if it was a non-idle relief engine because as mentioned you can't get a accurate reading on compression but will have the same increase. A lot of factors come into play but I would agree 28 would be safe. We have ran 26cc here but have better fuel. Just my .02
    James Perry
    Northern Minnesota
    Do you measure cc size with or without the spark plug hole filled
    Sep 2002
    Dunlap,TN.
    With the plug that you would run such as a NGK BU8H installed in it.
    James Perry
    Northern Minnesota
    Had them cut down to 30 cc should a guy polish up the combustion chambers as long as the heads are off
