Results 1 to 9 of 9
    Middle East
    switch box testing
    Dear all
    I have question regarding mercury 2.5 260 hp switch box testing how can I test it if its working good or bad and whats the perfect reading (ohms ) for it
    please let me know
    regards
    Yasser
    Dec 2011
    Ludington michigan,on the shore
    What problems are you having? You can swap the packs around,if the problem follows the pack,it's bad.
    Outasite is correct. You need a DDT to test one and even then its not completely accurate. Depends on where the short might be. Also switch box reacts differently when in real world operation.
    Middle East
    Hi
    I have problem my engine is 280 hp with 260 electronics but my engine is not turning more than 9600 rpm even with small pitch of propeller so I think there is problem with the switch box because I do testing for stator and trigger and coil its all same as chart specification and I do test for switch box I get different reading than the service manual (1300-1500 ohms ) but I get( 764 ohms )
    please let me know iif you have idea .
    what's the problem with my engine .
    regards
    Yasser
    Aug 2009
    savannah,ga
    Whats the rev limiter in your computer?
    Middle East
    there is no rev limit in my ACU is brucato with no rev limit and its setup up 13000 rpm
    Dec 2011
    Your total setup will have a lot to do with max rpm,9600 with stock 280 porting,I would think your on the backside of the curve.Do you have access to another switch box,or better yet a pair to try out to see if there is a difference?
    Jul 2009
    Crawfordville fl
    9600 is about it for 280 with stock porting
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
    Feb 2007
    lily lake WI
    Quote Originally Posted by bigbluechevy454 View Post
    Yep with 1.87 gears that's it 2.1 gears around 10,000 but trust me a your not going any faster the trick is to keep the motor in it's power band and past 9000 rpm's a stock ported 280 is done
