Results 1 to 15 of 17
Thread: Sei lower unit lwp
11-16-2014, 07:05 PM #15000 RPM
- Jun 2009
- Key Largo, Florida, USA
- 120
Sei lower unit lwp
For sale SEI lower unit has maybe 10 hours on the lower and 1 hour on the lwp
$400
11-17-2014, 09:39 PM #26000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
Prop shaft shear off or just without guts?
11-18-2014, 11:55 AM #35000 RPM
- Jun 2009
- 120
Prop shaft shear off worked perfect until the shaft snapped
11-18-2014, 11:18 PM #4Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
is that holes from a blown pinion gear
11-19-2014, 10:38 PM #55000 RPM
- Jun 2009
- 120
No holes that's some paint that came off
11-20-2014, 08:07 PM #6
BUMMER no warranty...they have been pretty reliable...did you hit something, did it break at the thrust washer or internally??
11-21-2014, 07:38 PM #75000 RPM
- Jun 2009
- 120
Didn't hit anything I ran it for 1 hour after putting the LWP. Broke at the seal
11-21-2014, 07:51 PM #86000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
I had one did the same thing. They don't like being surfaced much
11-26-2014, 12:10 PM #9
i have one that just did the same thing too..i think a non ratcheting prop shaft will fit as a replacement. mine has very few hours as well..loosing a prop completly sucks!!
11-30-2014, 11:14 PM #10
11-30-2014, 11:18 PM #11
12-01-2014, 10:12 AM #125000 RPM
- Aug 2006
- virginia
- 666
- 39
- 65
- 282
- 732
12-19-2014, 05:24 PM #13Junior Member
- Aug 2013
- United States
- 20
I just fixed a sei with a lwpu for a customer I had to pull the carrier and shaft at the same time with a slide hammer then air chisel out the shaft back through the carrier as it broke right at the seal like many others, ruining the bearing in the carrier. It was only ran about 3 hours I looked spun welded together I'm no expert buy maybe where the tool steel ends and the stainless begins? I put what I believe is a merc. one piece shaft in it and hoping to different results.
12-19-2014, 08:32 PM #145000 RPM
- Oct 2012
- savannah
- 117
I have one of these lowers for sale cheap i have had no problems with it i went to a sporty it may have 2 hours on it .
12-19-2014, 11:45 PM #15
does that mean it's a lwp, 20" 187, rh, late mdle, for sale cheap...what does that mean...can't you be more specific...my 2 cents
