Results 1 to 15 of 21
    Dec 2012
    nc
    allison bottom question
    what is the difference in the xr-2001 drag bottom design (pre 1996) vs. (current)? Is it the size of the lip, design, pad, etc?
    shreveport,la
    There's quite a bit of difference. Dead rise, setback, etc. It's totally different. New bottoms tend to be easier to drive and a little more forgiving
    Erik Kiser
    alabaster , al
    Depends on what you want out of it, 99% of the allisons running around the country are fast off the showroom floor, the new style bottom design is just as fast but a little easier to drive in certain situations ( motor/setup/etc...)
    if you want to drag race 800' or 1/4 mile then thats a different story, any allison can compete but there are only a handful around that have the extreme bottom modifications to run up front every week ( thats a big difference in heads up racing) and its not cheap.
    so if you want to hit the track and race then setup and bottom mods are a must, if you want to play around the sanbars then its not that big of deal what style you have....
    and of course whats on the back and gearcase design/ prop selection is a major factor..........but if you have a fast boat to start with it makes everything else alot easier..
    Dec 2012
    nc
    What is the factory lip measurement on the older model hulls? Mine is at .61 thousandths. debating to knock it down a bit or not.
    Oct 2003
    Richmond,Va.
    The 2001 and newer XR-2001's have basically the same bottom as the SS-2000. The pad is narrower is the main difference.
    Lee Sanderson
    Dec 2012
    nc
    Just curious, what is the width of the new pad. I'm at 9" and the roll tapers down towards the outside edges.
    Dec 2012
    nc
    Oct 2003
    Richmond,Va.
    I'm not sure on the width. .061 and tapers off on the edges sounds about right (standard) on your pad.
    Lee Sanderson
    Sep 2007
    Pensacola FL
    I know of several stock untouched new bottom boats that are winning in DSRA /ODBA. No bottom work needed IMO.
    shreveport,la
    Quote Originally Posted by carguylsx View Post
    Should clean up and run the bottom half of the track. I'd be hesitant to mess with it. Work the setup to fit it. Won't be able to run a bunch of motor height
    Erik Kiser
    shreveport,la
    The older drags were a deeper molded depth and steeper deadrise .. New ones a little flatter
    Kevin Kiser
  12. #12
    charlotte,nc
    These are two different hulls. I don't know what years.
    death is certain; life is not
  13. #13
    Dec 2012
    nc
    thanks for the all the info. mine is a 93 and runs like the one in the pic with the merc. Just playing with setup, boat feels loose, just doesn't air out as much as I thought it would. had a 88 xr 2002 that lifted a lot more but never looked at the bottom on it(had it years ago)
  14. #14
    shreveport,la
    What you're describing is what I'd expect out of the hull you have.
    This boat was a 93 with a lip like yours and was very quick early on and loose on top. Couldn't run much higher than about 1/2" above or it'd turn around getting out of the gas
    Erik Kiser
  15. #15
    Nov 2010
    orange tx
    I have a 2014 drag with no bottom work and it will hold its on with any gas boat that races now day's.IV never had the bottom touched on either of my alli drag boats and both have been very competitive. Bottom work isn't going to turn a middle of the pack boat into a winner.
