Results 16 to 24 of 24
Thread: promax high water pressure
10-19-2014, 08:13 PM #16
There's a triangle shape opening in the block under the poppet, it's where the water exits. There needs to be a matching opening in the cowl plate, frequently the 260 plate will not have the opening, so by using that plate you've plugged the poppet. Somewhere I have a photo, I'll see if I can round it up.
10-19-2014, 08:17 PM #17
10-19-2014, 08:39 PM #186000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
Had the same problem with a promax power head and 4 hole CLE and 260 plate. Had a small hole where the poppet dumps. Opened it up to the triangle size. Made no difference. Tried everything else. None of it worked. 35+ PSI at WOT. Finally said screw it and ran a 7/16" drill bit into the 2 piece adapter water dump passage into the mid and opened up the 4 coolant holes that spray the tuner to 1/8" . Those two mods dropped terminal pressure to 20-25 lbs at 80+ MPH and didnt affect the idle pressure at all.
10-19-2014, 09:12 PM #19
10-19-2014, 09:13 PM #20
10-19-2014, 09:21 PM #21Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
Those dang Merc engineers.....
Dave Hensley
1986 XR2002 /12" Mariner and string steering
18' Pugh Hydro
1992 XTB-21/225 ProMax
The barn is emptying out!!!
10-19-2014, 09:22 PM #226000 RPM
- Dec 2011
- Sunny Oregon
- 1,768
- 13
I'm running a 2 piece as well. Problem being that the 2 piece dump hole that the poppet feeds isnt big enough to release all the water the low water pickup is feeding it. The pump is really doing nothing at high speed. Its the ram effect of the water entering the system that is feeding the motor cold pressurized water. The poppet can be wide open but with too small of a dump port the pressure stays high. You'll find the same thing.
10-25-2014, 05:11 PM #23
Opened up the cowl plate, fixed the issue. A big THANK YOU to Transomstand for the insight.
Question, what temp should I see this motor running at? Getting 125 on gauge, not sure I trust it. Running 8 lbs water pressure at idle, 18 at WOT. Seems to be working great. This board is great, knowledgeable folks.
KurtLast edited by ActivatedSludge; 10-25-2014 at 05:11 PM. Reason: spelling
1992 Allison XTB 21 / 225 Promax
10-25-2014, 08:06 PM #24Living in the Freedom provided by Bud Conner and his fellow warriors.
