Results 1 to 6 of 6
Thread: omc tilt & trim motor
10-16-2014, 03:34 AM #1Junior Member
- Jan 2013
- finland
- 25
I have a -91 Evinrude 150 xp v-6 that has a tilt and trim unit with a 2-wire electric motor. It is not the original unit of this engine. the electric motor stopped working, eaven if i feed it directly from battery. What year engines used the 2-wire setup? Will a 3-wire setup fit physically? Just so i know what part to order.
Thanks in advance.
10-16-2014, 03:43 AM #26000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
The last year for the 3-wire motor was 1981. OMC changed to the 2-wire motor mid-year and they've been 2 wire ever since. A 3 wire motor may fit and work, but it requires a special solenoid control box (NLA) which is pretty large-fits under the rear splashwell of the boat and wires direct to the battery. A rather clunky old system. I'd stick with a 2-wire replacement motor in order to use the newer dual trim relay control box that mounts at the back of the engine, under the cowling.
10-16-2014, 03:47 AM #3Junior Member
- Jan 2013
- finland
- 25
So the 2-wire motor is newer? I thought the opposite...
10-16-2014, 04:40 PM #4
2 wire is newer.
10-16-2014, 06:03 PM #5
I have had mine stop working a couple times and took it apart and it was all rusty. I was able to clean it up, put it back to gether and it worked. It may be worth a try. Its hard to get the brushes to stay while putting the winding back in. I used paper clips to hold the brushes from attracting to the magnet. I have the same 91 xp150.
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
10-16-2014, 10:24 PM #6Junior Member
- Jan 2013
- finland
- 25
Thanks for the replys. I'll try taking it apart. At least nothing to loose...
